D15 series 2 Hydraulic pump
whiteheather View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whiteheather Quote  Post ReplyReply Direct Link To This Post Topic: D15 series 2 Hydraulic pump
    Posted: 05 Feb 2012 at 2:08pm
I am new to using a tractor, i got a AC D15 series 2 tractor, the hydraulic pump was given to me in a bucket of oil, and a makeshift motor was installed on rear of tractor, (which works fine) however i would like to have the old pump fixed or replaced, if any member has a pic of a D15, and the location to where the pump mounts too, I would be grateful of any help. many thanks in advance.  i am a new member to the forum here, and the info is awesome.  located in B.C. Canada.......................whiteheather
Travis(NE) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 3:13pm
The factory Hyd pump would have been located inside the torque tube. An optional pump could have been in the belt pulley location.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:52pm
  it mounts on the front casting infront of grill
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:54pm
  can you a pic of the pump?????????   will help
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 7:07pm
Are you looking for the pump that powers the rear lift or do you have a loader for the tractor that you need a pump for? Loader pump is low pressure/high volumn pump mounted in front of grill, rear lift pump is mounted in the belly of the tractor behind the clutch housing just inside the cover plate with the drain hole.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote whiteheather Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 8:42pm
yes tractor has a loader, the pump is for loader/bucket.   ty
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:04pm
I have this one that is missing the front plate....if you have the plate, measure the distance between the holes.  This one might work for you.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote whiteheather Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 3:50pm
Eldon
many thanks, would you have a picture as to where the pump is located, i am at a loss, and new to this.
many thanks
Charlie
Post Options Post Options   Thanks (1) Thanks(1)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 4:12pm
If it is the factory installed high pressure low volume pump used for the rear lift arms it will be mounted in the belly of the tractor ran off of cam lobes on the main shaft in the torque tube. It would be in the same location as the one I circled in this picture of a D17...
If it is a factory auxiliary pump used for a loader or anything else it could be up front driven of the engine front crankshaft pulley or in place of the belt pulley on the right hand side of the torque tube between the engine and operators station.
Or could be aftermarket ran off of the PTO out the rear of tractor.
Edited by Travis(NE) - 06 Feb 2012 at 4:13pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 4:31pm
Originally posted by whiteheather whiteheather wrote:
Eldon
many thanks
Charlie
Check to see if it looks like something was bolted to the front of the tractor.  Most have a splined shaft that ran under the radiator and slid into a coupling on the crankshaft pulley. They usually had a double row chain coupler from the shaft to the pump....and a sheet metal cover over the pump to protect it.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 4:39pm
Oops I missed that part... Sorry
Then it may have looked like this...
This is the A-C setup for the 400/500 series loaders on my 19. On a 15 the grill would not need to be cut out.
Edited by Travis(NE) - 06 Feb 2012 at 4:46pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 5:07pm
Eldon
Hate to be picky but the way I remember it:
the 400 Series loaders ( 445, 414, 415, 417 } had the pump out front like in your picture,
 and the hydraulic oil was in the loader frame.
the 500 Series loaders ( 517, 519 ) the pump was on the R/H side of tractor,
   and hydraulic oil was in the normal location for 'D' Series.
Gary
This page was generated in 0.123 seconds.
