Washing Soda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Washing Soda
    Posted: 01 Feb 2012 at 8:12am
I have seen mention of washing soda on this site especially for cleaning radiators and engines of gunk.  In one thread they mentioned Wallyworld for getting it.   Is 'washing soda' Arm and Hammer laundry soap?  I searched Wallyworld for 'washing soda' and came up empty.  Whats the name for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:19am
It's a pool treatment chemical.Changes ph. Got one in the shop but can't remember name.
   SODIUM CARBONATE
Edited by SteveM C/IL - 01 Feb 2012 at 8:22am
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:21am
Many laundry soaps may have washing soda in therm but you're looking for washing soda only. It is different from baking soda. Although I've been watching the selves at Walmart for several months I only found it stocked in December. Bought two boxes. Prior to that I purchased it from a pool service guy. It is cheap! Dish washing power may contain more washing soda than laundry. I'm sure better chemists than I will add to this tread.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:32am
I think it is also called "TSP" (TriSodaPhosphate). TSP works great for flushing out my tractors.
Ed-In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed-In Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:40am
Is this the same as " Iron Out" and can this be used to put in radiator to clean it and the block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:42am
I don't think phosphate and carbonate are the same thing. Phosphorus VS Carbon
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:29am
Sodium Carbonate.
 Arm and Hammer Super Washing Soda.
Comes in a 55 oz. box.I bought a box of it (I believe at Wallyworld) last summer to get the "funky" sweat smell out of my work clothes when I wash them.
I used it back in the 60s to flush the cooling system in my Flathaead '50 Ford P.U.
Worked quite well but you would think there might be better alternatives today?
I think "Iron Out" contains Oxalic Acid.
Oxalic Acid Crystals can be bought in a drug store.
Years ago we had a real bad rust build up in our dishwasher and someone told ust to buy the Oxalic Acid crystals and run it thru a cycle; you would not believe how it took the "red" out!
I don't remember how much I used but I had purchased a 1 lb. bottle and I think there is more than 3/4 of it left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 11:13am
We used SPREX for pre-cleaning metal before coating it with photo-resist for chemical milling process. Used in a hot tank for soak and dip cleaning.
 We also used it in electrolysis cleaning before milling process to remove any residue left and any surface oxidation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 12:30pm
I have bought the Arm and Hammer super washing soda in Publix and Bi-Lo grocery stores. I use it in my electrolysis tank. Have not tried it for radiator cleaning.
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 2:13pm
Fareway stores carry it in central Iowa
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 2:13pm
In the Northeast, it is carried in Wegmans supermarkets.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Allis B in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 2:19pm
I can find it in most grocery stores here in the northeast as well...I use it to make laundry soap
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 4:22pm
Ted you won't find it around here. Go to the pool department and get sodium carbonate . It's used to increase ph in pools.  I have some around somewhere. Same stuff to use for electrolysis rust removal.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 6:30pm
I get it at Rural King... TSC or Farm and Fleet might have it.
Jason in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason in MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 7:09pm
You could take regular baking soda and put it in an over to make your own washing soda. At temperatures above 300°F (149°C), sodium bicarbonate decomposes into sodium carbonate.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:12pm
According to my Merck chemical index, washing soda is the decahydrate of  of sodium carbonate. And sodium bicarbonate is made from sodium carbonate, water, and carbon dioxide. Merck says that sodium bicarbonate looses co2 at 50C and by 100C is sodium carbonate. In a water solution it begins to break up into carbon dioxide and sodium carbonate at 20C and completely on boiling.
The sodium carbonate decahydrate known as washing soda is also known as sal soda, natrite, or natron.
Gerald J.
This page was generated in 0.266 seconds.
