WD enginge in a WC |
chickenmann ![]() Silver Level ![]() Joined: 15 Jan 2011 Location: Brooks, GA Points: 87 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2012 at 1:56pm |
Is it a direct swap to put a WD engine in a Styled WC or is there a conversion that must be done?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21830 |
Pretty much, unless there needs to be a hole in the hood for a muffler.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2198 |
Yep, there's a WC sitting in a fencerow nearby with a WD engine. Without actually having done the swap, it looked like it basically bolted right up.
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
201 engines in a WC and WD are identical. Bolts right up. A 226 from a WD45 bolts up just the same too. Like Dr. Allis said, unless you have to add a hole for the exhaust. WC manifolds were side exit and WD 's came out the top.....the manifolds are interchangeable too.
Edited by BennyLumpkin - 16 Jan 2012 at 10:02am |
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11741 |
Side exhaust were normally found only on Distillate engines. Not Gasoline models.
