problem with my HD4 dozer
moquinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moquinn Quote  Post ReplyReply Direct Link To This Post Topic: problem with my HD4 dozer
    Posted: 03 Dec 2011 at 12:46am
I'm loosing fluid from my torque converter into my transmission.  i know it's probably a bad seal, but wanted to know if anyone knew of anything else that may be causing it before i went into massive undertaking of tearing it apart to just fix a seal. any help or suggestions are appreciated.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 12:02pm
I  had the same problem, and had to pull apart tranny and torque housing. the seal was bad as well as the rings and clutch hub grooved. big job ! randal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2011 at 5:22pm
did you find the problem ? hope it was not as i thought. randal
