Need advise for A-C 6070
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Topic: Need advise for A-C 6070
    Posted: 03 Aug 2011 at 4:58pm
Going to look at a 6070 2wd with loader for sale.  I Have no experience with the 6000 series. Would like to know some things to watch out for or that could be costly to repair with this model A-C.
    Thanks
      Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 6:31pm
Anyone know the good or bad of a 6070?  The one we are going to look at tomorrow also has rops canopy. Guy says it runs well and he uses it only reason for letting it go is that times are tough.  Thanks for any input.
                                                       Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 7:06pm
Overall good tractor. You may find hi reverse to be too fast and medium reverse to be a little slow for loader use. Condition of the clutch would be my biggest concern on a loader tractor.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 7:20pm
good series clutches are expensive to repair check if it has the brace bracket down on front on the crankshaft
Farm stuff 8050,6690,175,F2,5050,WD
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 10:00pm
I could be wrong but I think the 6070 is new enough that it has the heavier internal thrust bearing so the external one wouldn't be there at all.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 10:00pm
Thanks for the info and suggestions. I will check for the clutch and the brace on the crankshaft. Will post again with some pics. Hopefully we will be able to come to a deal so we can bring another A-C to a happy home. :-)
