Need help on I600 Hydros
Freighttrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freighttrain Quote  Post ReplyReply Direct Link To This Post Topic: Need help on I600 Hydros
    Posted: 13 Jul 2011 at 9:58am
Why would this valve have a allen bolt in the middle?Does the steering system get it's fluid from this valve.From what I can see without a flashlight,the hydro hoses hook to it but there is so much sludge built up in there I can't be 100% sure.Wonder if this is why I have NO pressure to the steering ram even though it is hooked up.I can arm strong the wheel and get the rear to work even though there is no mechanical linkage so there is some fluid getting through the system in the correct direction just no pressure......Also,before someone ask,this is a I600 tractor and a 614 model forklift.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 4:03pm
Do yourself a favor and buy a book. That will answer many of your questions.
