"C" Hydraulics Install
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Topic: "C" Hydraulics Install
    Posted: 14 Jun 2011 at 10:19am
 I would like to put hydraulics on my "C".  Does anyone have a complete, usaeable or rebuildable unit for sale?
How much better are the 4 piston "CA" pumps? Do they make more pressure or are the just a higher flow? I assume the cam in the PTO housing will need to be changed to match.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 10:29am
The CA pump has 4 pistons vs 2 pistons on the B/C pumps. Both have the same pressure; the CA has more flow. One would need to install a PTO shaft (and maybe the pumpkin on the back) from a CA to install the CA pump. You would also need to install the CA hydraulic control valve.
I have used the 12 volt hydraulic pumps (available in single acting or double acting) on the CA and D14 to save the hassle of locating parts, valves and plumbing.
