200 vs 210 hyd remotes
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: 200 vs 210 hyd remotes
    Posted: 08 Jun 2011 at 6:13pm
I would like to put a set of hyd remotes on my 210 like the style that is on my 200. The 200 has the lever on the side of the female outlet that ya pull towards you and the socket comes toward you and the hose comes out. Now, is there anything special about that style of outlet? looked to me like there was a seperate  groove in it that the lever was slid into.. Maybe im wrong.. Long story short, can I go to farm and barn and just get a pioneer outlet, or is this a special item? thanks.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 6:20pm
They're a quick release. They are designed that if the implement comes unhoked the hoses will pull out of the outlet and not pull the hydraulic outlets and lines off the tractor. The extra grove is for a snap ring to hold the outside of the coupler and the inside moves.
This page was generated in 0.056 seconds.
