Drilling with a B
Tom in IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom in IL Quote  Post ReplyReply Direct Link To This Post Topic: Drilling with a B
    Posted: 31 May 2011 at 10:13pm
Is it possible to pull and plant with a drill using a Model B?  I realize the hydraulics would need to be modified, but wanted to know if anyone has ever done this wiith success.  Sorry if I am way off on this topic, but I have only had experience with a planter, but would be more interested in a drill.  Thanks for the help in advance.
Tom
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 12:15am
I pulled a 6 ft press drill with a C once on about a 6 acre job. The tractor had a wide front but still steered awful with those small tires in the soft dirt. I had fluid in the 9.5-24 tires but I still had alot of wheel slip. So If you have tight steering and extra weight it shouldn't be too bad.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:58am
A lot depends on the drill you use.  If you have access to an old rope trip drill, you will have no trouble.  Here's my C with a 13 x 7 Oliver Superior drill that was made about 1948:
Edited by BrettPhillips - 01 Jun 2011 at 7:58am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 10:32am
I have drilled with this Oliver drill using my B with the belly mower under it.  Doesn't take a big tractor to pull a drill of this type
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom in IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 9:53pm
Thanks for all the responses and help.  Dick L, how did you set up your hydraulics for the model B?  I have a 1947 AC Model B with 1 pump, but it does not have a remote.  It looks like that Oliver has hydraulic lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 8:17pm
That Oliver drill has two ropes. Both sides have independent lift clutches. No hydraulics! You can drill with only half of the drill.  When your drilling beans starting on the outside working toward the center going around and you only have a narrow strip in the center that is less than half the width of the drill you can lift one side and save the seed. Can make a difference on a real long field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom in IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2011 at 10:12pm
Dick L - What size and type of Oliver drill is that in the picture.  It looks to be in excellent shape.  Thanks again!
Tom
