220 Front Weights Wanted |
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Mar 2011 at 1:20pm |
Hello all,
Looking for a full set of Allis front weights for a Two-Twenty, does anyone have a set around central Nebraska, or a set from another tractor that would work. I don't know if the Two-Ten is the same or not, the D-21 set is different, so I don't know. But if anyone does, please let me know. Thanks in advance!
Still in use:
dpower ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Madison Ne Points: 1578 |
andy gubbels had a set of these for sale. He is located in Northeast Nebraska.
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3841 |
In case you were not aware of it there is two ways to go, suitcase weights & bracket or the big starter weight and add on slabs. I think the suitcase weights were used more on the 210 than the 220 for unknown reason. |
Thanks for the info, I emailed Andrew. Was the suitcase weight opion a factor option, or somthing that worked, becasue the bolt pattern was the same.
Thanks again!
Still in use:
Chad (MN) ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: sc minnesota Points: 288 |
The suitcase weights must have been an option from the factory or dealer installed. My 220 had the bracket "marks" on the frame, so I put a set back on it. Butch is probably correct that more 210s had the suitcase style weights than 220s. Chad
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
