Problems (2) with New C |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Topic: Problems (2) with New CPosted: 18 Mar 2011 at 9:07am |
I just bought a C and it has a lot of parts that need replacing, fixing up.
My front end wobbles something terrible when I go down the road. There is about 10" of play in the steering wheel. I don't know if there is an adjustment or not? Also the long steering arm on the side has a couple of problems. The joints are wore out I would bet. The one nearest the front end has the nut welded in place. Is this arm still available? Do the joints press out, so you can re-grease the bearings, or are they closed? I have fluid leaking out of the left rear wheel. There is a LOT of grass (Hyd soaked) in the wheel hub area and I need to clean it out first before I can tell where it is coming from. Is there a gasket or seal that is probably bad? Is this available? So far these seem to be my WORST problems. It runs like a top with no smoke. Another problem is the wiring. I'll post that separate. Thanks guys. |
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 18 Mar 2011 at 10:58am |
Wobbling in the steering can be a result of any/or all of the following: worn tie rods, worn steering gear boxes, and/or worn wheel bearings. Try to determine where the play is by watching as you move the steering wheel. The long arm has tapered ends that go into the shorter arms; use a "pickle fork" to remove the arm (since someone seen fit to weld the nut on yours, you will need to cut off the nut 1st). Best bet for the long arm is to either rebuild yours or obtain one from a donor tractor.
There are seals between the final drive and the tranny that wear out resulting in oil getting into the finals and dripping out and/or soaking the brake shoes. The seals are available from most any AGCO dealer (use the AGCO ones, as the auto store ones are a lot flimsier and prone to being damaged when reinstalling the axle). One needs to pull the finals to replace the seals, best to use a hoist as the finals are very heavy.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Ted J
Posted: 20 Mar 2011 at 7:01am |
How do I tell which steering I have, the Ross or the Gemmer steering?
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 20 Mar 2011 at 7:55am |
A Gemmer will have these bolts showing around the out put cross shaft. The Ross will not.
![]() ![]() Edited by Dick L - 20 Mar 2011 at 7:55am |
Blake_AllisMan
Joined: 25 Oct 2010 Location: Plainfield,IA Points: 413 |
Posted: 20 Mar 2011 at 4:14pm |
More than likely the steering box and the front end steering are wore down. My dad and I put shims in the front end steering so that the gears would mesh closer together to stop the front end from wobbling. Its amazing what one little shim well do to your entire front steering. The only big downfall with the "C" was that Allis Chalmers didnt put any grease fittings on the steering arm to make it easier to maintenance. I would maybe suggest going to a local tractor yard and looking for one that is half way decent.
1941 C
1952 IB 1947 C 1955 WD45 SFW 1956 WD45 Diesel 1977 5020 4WD Serial Number 1 |
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 20 Mar 2011 at 6:26pm |
Ted, I might have some C steering parts here yet. I will go do a quick hunt and get back with you.
ChuckLuedtkeSEWI
Posted: 20 Mar 2011 at 7:01pm |
Ted, all I got is a ross steering box, with the arm on it yet that the long shaft attaches to. Steering box seems tight, but the support arm on it that wraps around the shaft on the left side and bolts to the frame tube has been rewelded. I also have a one bottom plow here with the lower mounts for a C, but I don't have the whole depth adjustment parts for a C. Those all went with the cultivators when I sold them. I have a B depth control lever which I think would work, but wouldn't be "correct" by the correct police.
Ted J
Posted: 21 Mar 2011 at 6:39am |
Thanks Chuck, but I have a Gemmer steering box. I don't think the Ross will work? Have to ask someone more knowledgeable, like Bill L. I guess when I get into it, I will decide then what to do. Thanks anyway, Ted
Steve in NJ
Posted: 21 Mar 2011 at 7:16am |
Ted,
We can supply you with a new wiring system kit if interested. 6V kit runs $135.+ 10.95 for the Postman.
HagerAC
Posted: 21 Mar 2011 at 7:31am |
To fix the steering arm on our C, what we did was get a couple of tie rod ends from Fleet farm, and then got a piece of tubing and welded a nut in each end, and then threaded the new ends in the tube, and used the other nut to lock them in place. It works nice, but is not technically the way to do it, but its just a work tractor anyway.
