What cutout for Allis G
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Topic: What cutout for Allis G
    Posted: 17 Mar 2011 at 8:32am
I'm hunting a 6-volt cutout for an Allis G.  What are other guys using?  Who sells them?
Thanks
Dick
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 11:40am
Steve @ B&B on this forum as well as the other vendors.
Gerald J.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 11:42am
Good mechanical ones are a thing of the past. We stock solid state ones that can be hidden under the original cut out lid if some fussing time is invested and you want it to look original.     $39.53       S>L>I.
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 1:51pm
Sorry SLI but I can't find this item on your website
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 8:37am
I offer an electronic version in a OEM Delco chassis, or replacement unit. Whichever floats yer' boat. Drop us a line if interested. Thank you Gerald for the referral!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 12:31pm
We don't have near everything on our website. With over 1/4 million dollars on the shelf we would find it overwhelming. Just e mail or call.   Bill
Sandy Lake, PA
724-376-2489
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 2:16pm
It's probably best to just go 'solid state' under the hood. While I've got  a couple spares lying around, shipping to the USA would probably cost more than buying from one of the 'local' vendors.So much for 'free trade'.
If you're handy with a soldering iron, all you need is a 100V 50A power diode and 10 minutes to modify your original cutout.Unless the correct cops look inside no one will know !
Currently I'm looking at making an inexpensive 12V alternator conversion 'bolt on' kit,on that doesn't require modifying the rear cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 6:06pm
When you make a cutout with a diode, you need to be sure to supply a heat sink for the diode because the best of silicon diodes will have up to a volt (minimum 0.6 volts) forward drop and at 30 amps that's 30 watts of heat to dissipate. A 50 amp diode hanging on wire leads won't survive that without melting the junction and shorting.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 7:46pm
Yeah Gerald, yur right, but I use Shottky diodes and my G Genny can only dump out 15 amps , on a good day.These diodes only have a forward drop of .2 volt unlike the 'normal' silicon diodes that drop .6 volts. I always use a big heatsink.One day I should actually read the specs on them, cause no I'm thinking they might be 50 V, 100 Amp.
Gad, getting old is great...forgetting stuff, dyslexic,heatburn after eating my once favorite meats,....great....just great...
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 8:03pm
  we have original cut-out on the shelf    1-800-254-3116
This page was generated in 0.250 seconds.
