262 Diesel Rebuild-Conn Rod Bushings
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: 262 Diesel Rebuild-Conn Rod Bushings
    Posted: 22 Jan 2011 at 1:07pm
Okay, with advice received out here I decided to buy new bushings for the connecting rods nfrom Agco.  The originals are bronze apperance and are continuos.  The new ones are grey colored and are split.
My problem is  that I was testing the new ones on the new piston pins and in order for the pin to slip into the bore of the bushing, it opens up the split by 1-2 mm.  This doesn't seem right.  I question then if this bushing will fit in the rod if the piston pin is in.  To note, the part number on the bushings is correct to the Agco parts book.
Has anyone else ran into this issue?
Separately, please check the classifieds...I am looking for some rockers and pushrods.
Thanks in advance,
Terry
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 1:46pm
All I know for sure is when rods were re bushed in my 220&8070 they had to be honed to fit the pins.You need an experienced  person to do this,not a beginner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 2:37pm
Steve is correct. You must have the old pressed out and the new pressed in. Once they are pressed in, they must be at least honed to fit. The best way is to have the bushings bored so the wrist pin is correctly located. Honing will work fine, just isn't as accurate.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 5:25pm
just make some from barelium copper
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 5:29pm
Looks to me as if you have the incorrect part with the correct P/N on it. Does the bushing press into the conn rod end?? if it does, then maybe it is correct and needs serious machining to get the pins to slip into it. Also, where is the oiling hole??
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 6:31pm
I agree. I don't think those are the right bushings. And they do need to be honed in for correct clearance when done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 1:42am
Those are correct. They look just like mine and have an oil hole. I got mine from Sandy Lake.
