Allis 7000 differential
Empirestate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7000 differential
    Posted: 22 Sep 2026 at 5:45pm
I made my first post back in the spring about my 1978 allis 7000. The opion was I had a differential problem. I'm finally ready to tackle it. Question, do I have to split it to get the differential out? Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 6:43pm
No split. Start by jacking/blocking up under the drawbar bail area so both rear wheels are off the ground. Remove both rear wheels and set aside. Until that is done, you really cannot do anything else. Lift arm housing comes off. Axles get pulled out 6 inches and bull gears drop down. Rear end cover gets removed. Brake assemblies get removed. Bull pinion shafts/gears get pulled. Bull gears then can be lifted out to access a couple differential bolts. Diff carriers get removed both sides. Diff rolls out the back hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 7:01pm
thanks a lot dr. I was hoping a split wasn't required. I'll post my progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 7:07pm
I've only done one like this. 7000's were pretty good.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 9:49pm
Uh, don't excited - what the good doctor just accurately described is not any better than 'splitting' the tractor. You are talking some heavy stuff... you will find who your real friecnd are :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 3:49am
I know it's not a walk in the park, but it's  got to be fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 6:24am
Getting off to a great start will be getting those rear wheel bushings broken loose from the rear axles. This REQUIRES the proper special AC pusher bolts and patience and penetrating oil and a sledge hammer swung correctly.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 7:39am
   I found that a 1 inch drive impact wrench helps  gets them off very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 12:21pm
i've been soaking it the last few days.I do have the pusher bolts. we'll see how easy it breaks loose.
What do you use the 1 inch impact on? The pusher bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 12:29pm
I'd be very careful using a 1 inch gun on those three small diameter bolts. On a 7000/8000 series larger bolt, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 1:01pm
update on my 7000 differential problem. Took the rear top cover off and all the gears look good. Jacked it up and when I turn the wheels I can hear some rattling in the differential, so I guess i'm on the right track. Took the wheels off and the 3 point lift arm assembly. That's where i'm at. Next have to remove brake pinion shafts and press axles out a little than I should be able to remove differential according to all the good advice i've gotten here. Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 8:15am
update on my differential removal. Got the axles pushed out and the final drive gears dropped down, but they still partially block the carrier bearings. So i'm going to have to remove the final drive gears, but they won't come out without raising the cab. Anything special I need to to do before raising it? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 1:53pm
Remove engine hoods and the small center hood ahead of the windshield. Raise rear of the cab until you have enough room to get bull gears out. Takes a homemade hook of 1/2" steel rod to get hooked into one of the holes in the bull gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 2:38pm
Thanks Doc. Didn't think about the sheetmetal, good point. Any linkage problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 4:02pm
Been 40 years. Go very slow. Maybe the gearshift linkage ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 5:55pm
O.K. i'll let you know how it turns out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2026 at 5:59pm
Don't remember about the hydraulic valve stack. Disconnect pins?? or let the stack move up with the cab. I'm sure something has to happen there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2026 at 4:29am
Yes, I thought I would put them in the down(retracted) position and watch them as I lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 4:34pm
Doc, success, had to disconnect hydraulic connections and raise cab about 5 inches. The rest wasn't too bad. Got the differential out and opened up. Turns out there is a broken spider gear causing my problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 5 minutes ago at 4:45pm
I've found a used differential. I am putting new thrust washers in before installing it. Any tips or advice I should be aware of putting rear end back together? I do have a service manual. Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 minutes ago at 6:20pm
If you can.....use your old differential case !! Your carrier bearings are shimmed for that case and the bearings already like each other. New thrust washers and cross and gears as needed into the old case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 22 minutes ago at 6:28pm
Thanks for that advice Dr. I'll have to double check, but I think there was a little scoring on the housing. I will look again in the morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 11 minutes ago at 6:39pm
Also, I think the side gears showed slight damage.
