WD & D series front weight
keithpearson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithpearson Quote  Post ReplyReply Direct Link To This Post Topic: WD & D series front weight
    Posted: Yesterday at 4:49pm
Can the OEM front weights for WD & D series fit on the WD45 diesel? If so what is the correct factory installation of the weights? I have searched the internet and no luck.. Any help is greatly appreciated..
WD45,160 6040,D14,D15,D17,D19,D21,and still looking for more
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 36 minutes ago at 7:42pm
Slab weights won’t fit on a diesel. Not enough shelf.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 14 minutes ago at 5:04am
None of the D series have any "shelf".
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 15 minutes ago at 6:03am
How about front wheel weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 60 minutes ago at 6:18am
I'm not  WD45 diesel fan, but maybe the extra weight of the 6-cylinder engine and two front wheel donut weights accomplishes about the same thing as a gas tractor with slab weights ??
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 4 minutes ago at 7:14am
Easy enough to make a weight bracket similar to what is on the D Series
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 17 minutes ago at 3:01pm
True.  They have brackets that bolt to the frame rails.  For a 45 diesel, a bracket would have to be fabbed up, there is no factory weight bracket for that tractor.
