Need help with drum brakes
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Topic: Need help with drum brakes
    Posted: 15 Oct 2026 at 9:30am
So backed the hay monster out of the barn the other day, and as it started moving, heard a big BANG out of the back axle.
Got it moved where it needed to  be, then found rear axle locked up. Jacked it up and what we found was left rear tires were locked up. Once we pulled it all apart, what we found was a broken retractor spring on the brake drum pads.  No worries, we just get a spring kit.
Not so fast........what spring kit? Truck parts place spent half an hour looking and came to conclusion it would need a Leland K196 kit. This one........
Except the springs in place, and busted one don't match up to the picture.
So in order to try to narrow this down, how does one go about knowing what axle, what brakes and brake drum kit I actually need? Are there any ID numbers to be found anywhere?
Believe hay monster was built on a Dodge D600 truck chassis, circa 1970, but that is a ballpark year only. Also believe rear axle is same one it left factory with, but no way of knowing for certain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 9:37am
Will be an Eaton, only Two with that series Axle Shaft and only One with Hydraulic Brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 9:38am
Two Cylinders per wheel, that series Bendix has LONG been Obsolete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 10:06am
I may need an interpreter......as this was my first ever look inside a set of drum brakes like this.....but guys at truck parts place also said it was ALL obsolete and not available......except some of them ARE available on ebay. But you need to know what it is you are looking at, to figure out which kit you need.
On the Leland kit, there are at least two other "similars" on ebay.......but really none of them look the same as what I'm seeing in this picture. But if you can ID the thing for certain, there are places with NOS to sell.
Or .........last ditch would be off to a salvage yard to find a truck being parted out. Problem with that is the springs you could get from there may not be much better than what I have now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 11:11am
Need to look thru 2-5ton truck brakes catalogs, will be a hit and miss to locating Similar or Close but none will be same. Some parts stores as the Carquest I work with here still have Older Paper BOUND catalogs where Could be any manufacturer still using a Similar setup.
May still come up empty handed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 11:26am
Major manufacturers for the Big Four GM DODGE FORD and IH were all similar Bendix Wagner Midland.
Midland was absorbed into Bendix, Wagner continues until closed completely, all are now under Meritor. 90+% of All medium duty Drum brakes are as our Allis machines NOS someone is sitting on or gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 12:25pm
Should there be a stamped number or name on the axle, or anywhere on the brake drum? Some way to at least ID it other than an informed guy knowing what it is he is looking at and going from there?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 12:26pm
Try all/any of the old time parts stores, and hope one has old paper book sitting around still.
Time flies when having that kind of fun. Must about 20 years since I was in brakes like that on my IH 1700. At that time my local NAPA got what I wanted. But that is several management if not ownership changes ago.Cry  Most of the help there today would be no help at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 2:22pm
You're lucky the dufus behind the counter even knew what a drum brake was.  All Dodge's of the same era and maybe even up to the point they quit making Medium Duty trucks will be similar for all single speed axles of the same weight rating. Two speed axles will be equally identical. Find the ID number on the axle itself and go to the oldest HD truck parts place you know of. Don't waste you time at car parts. If you can find a Dodge Medium Duty parts book for the approximate year you think the base truck is would be your biggest help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 2:09pm
Quick update. Found a partial K196 kit on ebay........and since it was $10 with free shipping, took a chance.
This was old spring that broke and this was new spring in the kit. I may have gotten lucky.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2026 at 7:23am
Looks Good
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2026 at 8:09am
Since I only have old stuff around, whenever I have good parts (springs, clips keeper and the like) they all get put into a box ad labeled, I may need them someday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 42 minutes ago at 6:40pm
So spring went on and looked to be a good fit. Except when mounted, brake drum was still locked up. Took it all back off and eventually took off both return springs and left brake pad. Aside from the broken spring (which had clearly been broken a long time), the fault seems to have been the self adjuster, which was locked up. Took all that off and got it freed up......all eventually back on........a guy needs as many hands and arms as an octopus......and brake drum would now turn freely.  As it stands now, all back together.
Test will be tomorrow when I fire it up to return back to the barn. If brakes work, victory will be declared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 26 minutes ago at 6:56am
Self adjusters are as much a PIA as disc brakes. The older manual adjusters on Dodge vehicles were simple and trouble free. Engineers have to justify their existence by designing new and improved things, like many of Fords better ideas, take the Edsel for example.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 9 minutes ago at 7:13am
When we were little kids, I remember my Dad would back the car up real fast, then slam on the brakes. He would do it 2 or 3 times, about once a month or so, claimed “the brakes worked better”.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 34 minutes ago at 7:48am
Yeah Lars, I have an old C 10 with drum brakes on all 4 wheels and I've done that before. Does seem to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 minutes ago at 8:05am
Self adjusters were one step up from the horse and buggy.   Old antiquated Bull Chit.. The auto adjusters did work great and adjusted as you backed up.. rolled the shoe in the opposite direction..
That being said, the new DISC brakes are great...  If your not getting 50K miles on a set, you doing something wrong... We have a 2019 Ford Flex with ceramic discs.. 68,000 miles and i am going to do the rear brakes this week... Front are ORIGINAL and still plenty of material left... Some guys are getting 100K on these discs..
