AC 170-175 Hyd pickup elbow? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11120 |
Topic: AC 170-175 Hyd pickup elbow?Posted: 19 Oct 2026 at 10:36pm |
Can't find an elbow, part #70256068-8, rubber elbow ate front pump to steel intake tube. Any help appreciated. Thanks, Tracy
Posted: 19 Oct 2026 at 11:00pm |
Is this the one you were having hydraulic system problems with ???
Tracy Martin TN
Posted: Yesterday at 6:01pm |
Dr Allis, it is the same tractor. Wanted to have a good one on hand if this one is bad. Got to take some sheet metal off to get to it. Thanks, Tracy
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1187 |
Posted: 1 hour 3 minutes ago at 7:26pm |
Tracey, I could order the other end that goes to the sump. I thought after 50 years the pump end would be bad too, but it looked like new, no sun shine on it I guess. I was told pump end rubber piece is no longer available from Agco. I took the sump pan off to check and clean the screen. That pan weighs 20 something pounds, and its not very big. Today it would be just stamped steel. Tim
