7030 Block Heater
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Block Heater
    Posted: 05 Oct 2026 at 4:24am
I decided to put a block heater in my 7030 in case it is needed this winter. It has had a combine engine put in it so it doesn't have one now. I don't know a lot of history on the tractor so I plan to change out the coolant at the same time. The question I thought of is what are the chances of the plug coming out clean after 50 years? And then is there a good way to repair the threads in the aluminum casting? Thanks in advance.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 7:28am
If it was mine, I'd have the engine fully warmed up to operating temp and carefully use a 1/2" impact wrench to get it to move and know it is loose. Have your hand on the socket to control what's happening to keep it from completely coming unthreaded !!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 31 minutes ago at 9:31am
Heat around plug to grow the AL ?
8070nc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 54 minutes ago at 11:08am
If that elbow is aluminum and you put any appreciable heat there the aluminum is so soft it will take the threads out with very little force. Id do what Doc said and with a impact wrench bump on it maybe back and forth until it moves after it does spray it with penetrant. Patience is your friend. You probably wont have any. Good luck
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 53 minutes ago at 11:09am
Trouble
1984 80780
1957 D14
616 tractor
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 31 minutes ago at 11:31am
Thank you for the advice, I had planned to work on it this weekend but the heater won't get here until next week. Everything I work on at work that is aluminum recommends letting it cool to room temperature before trying to remove anything. I hope it comes out clean and without too much of a fight.
Ted
55allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 7 minutes ago at 11:55am
My local blacksmith will heat it and cool it several times before even trying to remove it.
He’d remove it at room temperature.
On manifolds I will spray penetrating oil on it several months before it needs to be removed or when we get some new to us.
That way it gets lots of heat and cooling.
