D17 gas connecting rods
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 gas connecting rods
    Posted: 1 hour 60 minutes ago at 2:35pm
The book is saying that the pinyon rod needs to be to the left of 2 piston and to the right of the other 2, I’ve never heard of this before and want to make sure I’m doing it correctly, the pin needs to be centered but the rod is offset or are they both offset?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 54 minutes ago at 2:41pm
Also piston #1 is the one closest to the radiator correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 42 minutes ago at 3:53pm
#1 is at the radiator... #2 and #3 piston rods have the different offset ... if you put them all in the same way, the center two piston rods will drag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 35 minutes ago at 4:00pm
this is from the WD45 manual--- but similar ... problem is engine design with 3 main bearings and  1-2 between two bearings and 3-4 between the other two..
