F2 motor into a 6080
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: F2 motor into a 6080
    Posted: 19 hours 45 minutes ago at 7:58pm
Motor tag needs to reference 433T correct?
Front plate needs to be swapped correct?
How bad of a winter project?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 10 minutes ago at 8:33pm
F2/F3’s had 433I. K2’s had 433T.
6080 had 433I.
Edited by AC7060IL - 19 hours 4 minutes ago at 8:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 48 minutes ago at 2:55pm
Basically they are both the same engine.  Yes, the front plate would need to be switched to accommodate the hydraulic pump.  Intake manifold might also need to be switched so you have an intake heater.
Never did the swap, but probably just have to move some stuff from your old engine to the combine engine.
