what model plow is this |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4239 |
Topic: what model plow is thisPosted: 29 Sep 2026 at 8:48pm |
HudCo
Posted: 29 Sep 2026 at 10:12pm |
4 bolts on the shears three bolts in a straight line the the front one is alittle lower none of the center to center on the bolts is the same
Posted: 29 Sep 2026 at 10:24pm |
If the frame width can be assembled 14 or 16 inch width I'd say 70 series. Bolted only to one frame width 60 series.
HudCo
Posted: 30 Sep 2026 at 10:56am |
HudCo
Posted: 30 Sep 2026 at 10:59am |
does this help alittle bit dr. allis need to find shears for this and land slides also
Posted: 30 Sep 2026 at 11:15am |
70-series. There is more than one plow "bottom" for the 70-series. And that determines what shares or landsides. I have made my own landsides out of 1/2" or 3/4" flat steel. They won't last as many acres as OEM, but my plow days don't happen that often and new landsides sure do keep the plow straight when plowing.
Edited by DrAllis - 30 Sep 2026 at 11:18am |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2376 |
Posted: 30 Sep 2026 at 11:54am |
Are the shears 3 bolt or 4 bolt, that is something you need when looking for them.
Mikez
Posted: 16 hours 45 minutes ago at 7:29pm |
Unbolt and look for part numbers on back side of any of the wear parts
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4433 |
Posted: 6 hours 16 minutes ago at 5:58am |
Had to dig the bible out and review my Allis plows. The good Dr. is right, a model 74 pull-type. Not a real common plow. If it had cushion trip bottoms it would be an 84. Dave the plowman probably has wear parts.
Posted: 5 hours 42 minutes ago at 6:32am |
Not really a common A-C plow for sure. It would be interesting as to what tractor actually pulled it. It is set-up for a 14 inch cut, which in a mounted style would fit a D-17 in my neighborhood, but a pull type version takes more tractor to pull it. If it had been hooked to a D-19, I would have expected a 16 inch cut setting. Maybe it was pulled by a brand X tractor ???
HudCo
Posted: 1 hour 45 minutes ago at 10:29am |
i think this was a 5 bottom . some cutting has been done on the back at some time . this one was given to me. all i will use it for is plow days and parades but i will replace re build the cutting parts, just did all the wheel bearings and tires before itook it off the trailer . going to pull it with the d17d
Posted: 49 minutes ago at 11:25am |
If it was my D-17, the drawbar would be modified and up to probably 24 inches high. Good tread 16.9 x 28 tires FULL of fluid with 12+ psi. 600 lbs of rear wheel wts (300 a side). Need 300 or 400 lbs on the nose. Let the plowing begin !!
