what model plow is this |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4238 |
Topic: what model plow is thisPosted: 15 hours 50 minutes ago at 8:48pm |
HudCo
Posted: 14 hours 26 minutes ago at 10:12pm |
4 bolts on the shears three bolts in a straight line the the front one is alittle lower none of the center to center on the bolts is the same
Posted: 14 hours 14 minutes ago at 10:24pm |
If the frame width can be assembled 14 or 16 inch width I'd say 70 series. Bolted only to one frame width 60 series.
HudCo
Posted: 1 hour 42 minutes ago at 10:56am |
HudCo
Posted: 1 hour 39 minutes ago at 10:59am |
does this help alittle bit dr. allis need to find shears for this and land slides also
Posted: 1 hour 23 minutes ago at 11:15am |
70-series. There is more than one plow "bottom" for the 70-series. And that determines what shares or landsides. I have made my own landsides out of 1/2" or 3/4" flat steel. They won't last as many acres as OEM, but my plow days don't happen that often and new landsides sure do keep the plow straight when plowing.
Edited by DrAllis - 1 hour 20 minutes ago at 11:18am |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2376 |
Posted: 44 minutes ago at 11:54am |
Are the shears 3 bolt or 4 bolt, that is something you need when looking for them.
