AC 175 hyd fluid leak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 175 hyd fluid leak?
    Posted: 14 hours 4 minutes ago at 6:59pm
I noticed my 175 is very jumpy using hydraulics, lift, loader . It is a little low i checked , but here is the question. Setting on tractor, top of the lift resevoir there is an elbow. When I use the loader or lift it wants to puke a little out and runs downs housing. What is likely cause. What type of hyd fluid -trans are you using. Hasn't been changed lately. Does Oreillys stuff pass the test? Also with a FEL, how much more fluid do you top off with? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 58 minutes ago at 7:05pm
What is your chassis s/n ??? because yours may be the later model version and that is the breather for the hydraulic system. Like directly under the battery area ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 7 minutes ago at 7:56pm
Dr Allis, it is directly under battery placement. I can't remember the serial number, but is a late model with wishbone frontend. It does have the little tube underneath that ies the two compartments together. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 59 minutes ago at 8:04pm
That's late model and that is the breather. Your hyd dipstick is sealed and NOT the breather on yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 11 minutes ago at 8:52pm
Dr Allis, understood on that, filler has no vent hole. What would make it puke hyd fluid out the breather, and it a little low at that? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 45 minutes ago at 9:18pm
Let it sit overnite on the level and stabilize oil level and maybe settle down air in the oil. Fill up to the proper level tomorrow. Use the tractor again until it acts up and report what you've learned. Is the transmission OVERFULL?? If not, missing oil went somewhere. Your oil vomiting out the breather could be from air in the system ?? bad loader ram seals allowing air to enter ?? or may a hyd pump that needs resealing. I've never dealt with one of these later model versions, so I'm not really sure with not really much to go on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 17 minutes ago at 9:46pm
Dr Allis, I will do that and report back. It acts like air in the system.Thanks, Tracy
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 30 minutes ago at 7:33am
What type of hyd fluid -trans are you using?.
I always use the agco 821.
Just go with what the dipstick shows.  I usually try to keep it as close to full as possible with an FEL and haven't had any issues.
It does sound like there is air in the lines.
