AC 175 hyd fluid leak? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11091 |
Topic: AC 175 hyd fluid leak?Posted: 1 hour 47 minutes ago at 6:59pm |
I noticed my 175 is very jumpy using hydraulics, lift, loader . It is a little low i checked , but here is the question. Setting on tractor, top of the lift resevoir there is an elbow. When I use the loader or lift it wants to puke a little out and runs downs housing. What is likely cause. What type of hyd fluid -trans are you using. Hasn't been changed lately. Does Oreillys stuff pass the test? Also with a FEL, how much more fluid do you top off with? Thanks, Tracy
Posted: 1 hour 41 minutes ago at 7:05pm |
What is your chassis s/n ??? because yours may be the later model version and that is the breather for the hydraulic system. Like directly under the battery area ??
Tracy Martin TN
Posted: 50 minutes ago at 7:56pm |
Dr Allis, it is directly under battery placement. I can't remember the serial number, but is a late model with wishbone frontend. It does have the little tube underneath that ies the two compartments together. Thanks, Tracy
Posted: 42 minutes ago at 8:04pm |
That's late model and that is the breather. Your hyd dipstick is sealed and NOT the breather on yours.
