170-175 dual pto |
Josh N
Joined: 01 Feb 2019 Location: Roaring spring Points: 66 |
Topic: 170-175 dual ptoPosted: 21 hours 1 minutes ago at 1:00pm |
Is it possible to take a dual speed pto housing off the rear end housing of 185 and bolt it on the back of a 170-175 ?
Posted: 17 hours 48 minutes ago at 4:13pm |
Yes. But you'll not have a 540/1000 RPM PTO. You'll have a 270/540 PTO.
Josh N
Posted: 14 hours 5 minutes ago at 7:56pm |
Ok. Can you bolt a
185 transmission housing to a 170-175 torque tube? I would think the transmission input shaft would be different because of the different power directors? Now that I think about it you would have to change the gearing up in bottom of torque tube like you have to when putting a dual pto on a 190 Edited by Josh N - 14 hours 3 minutes ago at 7:58pm |
Posted: 2 hours 8 minutes ago at 7:53am |
Yes. The Allis 540/1000 PTO system all started up front with the PTO being 1000 RPM and then getting reduced to 540 at the rear gear train. No way to alter that on D-19's on down. The mighty One-Ninety was their first tractor to have PTO design change which involved with two possible speeds and a hydraulic clutch. They didn't incorporate true "independent" power at that time and probably should have.
Alvin M
Posted: 28 minutes ago at 9:33am |
AC 170-175 Shuttle Had 540-1000 pto
Posted: 2 minutes ago at 9:59am |
Yes, they did. And I remember them being a very odd speed, like 800 RPM on the 540 side ?? something not normal anyway.
