Model B Stiff Rotation |
| Author | |||
TL73
Topic: Model B Stiff RotationPosted: Yesterday at 10:23am |
This tractor is a 38 and as you know hand crank only. Complete tractor was restored probably 15 years ago and has seen little use. To me, the hand crank seems much harder than expected. Even with the spark plugs removed the rotating assembly feels like it's way too tight. Even cranking it over with no sparks plugs shakes the entire tractor. I've seen people who can turn their engine over by rotating the cooling fan with the plugs removed. There is absolutely no way I could rotate this engine by turning the cooling fan. Is this normal?
| Sponsored Links | |||
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1014 |
Posted: Yesterday at 12:54pm |
How have you tried disengaging the clutch turning the engine over? If there is no difference you may have to remove the oil pan and plastigauge the bearings. I definitely this was the case with one B where the bearings were too tight, with correct clearances the problem was fixed and the engine turned over easy.
Joined: 11 Sep 2009 Location: illinois Points: 91070 |
Posted: 23 hours 12 minutes ago at 1:07pm |
did the tractor run after the rebuild ??? Has it been setting for a while ???
You could have some rust on the liners / pistons / rings causing things to drag.. If you KNOW the engine ran good at one time, i would put some penetrant or oil acetone mixture in each cylinder and let it set for a day or two.. Crank the engine over and push this out the spark plug hole... If it seems to help, you could drag the tractor around with the truck with the spark plugs OUT and in gear.... should loosen things up..
Edited by steve(ill) - 23 hours 11 minutes ago at 1:08pm |
TL73
Posted: 15 hours 49 minutes ago at 8:30pm |
This is what's odd to me. I'd been turning it over by hand with the clutch disengaged. I released the pedal lock and tried it with the clutch ENGAGED and it turned over easier. Maybe I'm missing something but I can't understand how the engine turns over easier with the clutch engaged. It's still stiff but significantly easier than before.
TL73
Posted: 15 hours 46 minutes ago at 8:33pm |
Yes, the tractor runs pretty good; we've been pulling it off until I can figure out why the hand crank is so stiff.
Edited by TL73 - 15 hours 44 minutes ago at 8:35pm |
Les Kerf
Posted: 13 hours 33 minutes ago at 10:46pm |
Could the throwout bearing be dragging on the bearing carrier? Is the linkage properly adjusted? |
Phil48ACWC
Posted: 7 hours 36 minutes ago at 4:43am |
Could the bell housing be full of a mouse house?
TL73
Posted: 6 hours 6 minutes ago at 6:13am |
I'm checking that this morning and I will let you know.
TL73
I'll check that out this morning.
Posted: 4 hours 12 minutes ago at 8:07am |
dont push in the clutch... leave the tractor in neutral... check the PTO lever is DOWN and not engaged during cranking..
TL73
Posted: 3 hours 48 minutes ago at 8:31am |
So, I'm assuming with the clutch depressed, it's causing additional friction which is why it makes it harder to crank over by hand?
DanielW
Posted: 3 hours 43 minutes ago at 8:36am |
Trying to think how that could be. I presume they had the clutch apart (and probably replaced) during the rebuild? When you/they assembled, did you have the friction disc pointed the correct way? It's not uncommon for folks to assemble with the friction disc the wrong way around. The long side of the friction disc hub goes toward the tranny (away form the flywheel). I can't quite think if that would cause your problem of binding with the clutch disengaged, but I also can't picture it too clearly in my head. When you say it turns over 'easier' with the clutch engaged, how 'easy' is 'easy'? Still binding/shaking the tractor and impossible to roll over with the fan? Or much easier, such that you could easily roll it over with the fan? If the friction disc is installed the wrong way around, possibly the long side of its hub is rubbing/grinding against some component on/around the engine/flywheel, tranny input shaft, or the other side is against throw-out bearing when the clutch is disengaged? Someone who knows the B's better than I do can likely comment on that. Worth doing the quick job of removing the clutch inspection cover and taking a look (might need an inspection camera to look in there sufficiently deep to confirm friction disc orientation - there are a decent resolution inspection cameras available quite cheap that plug into your cell phone).
Edited by DanielW - 3 hours 41 minutes ago at 8:38am |
