WD45 engine clutch disc opinions
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: WD45 engine clutch disc opinions
    Posted: 17 hours 12 minutes ago at 6:55am
This might be opening up a can of worms asking for opinions, but it seems there are 2 different clutch disc available for the 45. One being a fabric style and the other a 4-pad. The 4-pad seems like it may hold up to more power though.  The engine will have the 4-1/8 overbore sleeves and pistons so it may have a few more horses then when new.
Does anyone have experience with these in a 45?  Thanks
D15D, D17G, 170G, 175D, and two 5050FWA
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 38 minutes ago at 8:29am
You will want the heavy duty style.
This is the style I prefer.
Edited by 55allis - 15 hours 37 minutes ago at 8:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 20 minutes ago at 9:47pm
How are you going to use the tractor ??  Those button clutches are made for more grabbing power with the same diameter/size and squeeze on the clutch disc. There's no need for that unless you have a pulling tractor that makes 75 or more HP. The button style discs are very hard on the flywheel and pressure plate surfaces over time as they eat away the metal. You do however want a 9-spring pressure plate for any WD-45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 26 minutes ago at 10:41pm
I have one like above on my 45 diesel repower with no problems. Dynoed at 91 hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 56 minutes ago at 11:11pm
Re-powered with what ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 34 minutes ago at 11:33pm
Think he's got a D19 engine
