Allis chalmers b camshaft resistance
Tcfcowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcfcowboy Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers b camshaft resistance
    Posted: 12 hours 48 minutes ago at 8:03pm
Hello all, I am working on a total restoration of a 38 model B, I installed new Clevite camshaft bearings, and when I put the camshaft back in, it seem to have a bit of resistance, my question is, should the camshaft spin freely, or is it supposed to have some resistance? Thanks.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 12 minutes ago at 8:39pm
Cam drives the oil pump, which adds drag. New bearings are snug on cam with break-in lube. Cam takes ~5' pounds to start turning and then less to continue turning. Cam should have no binding during rotations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 2 minutes ago at 8:49pm
did you swell any driving in? Roll it around some and remove. Look for bright(tight) spots and scrape down.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 39 minutes ago at 10:12pm
With nothing else attached (no oil pump, crankshaft, pushrods, etc.) the camshaft should rotate quite freely. I would use light oil for checking, use assembly lube for startup.
Edited by Les Kerf - 10 hours 36 minutes ago at 10:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcfcowboy Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 47 minutes ago at 6:04am
It takes probably, 5-10lbs to turn it with nothing attached, But it rotates smoothly once I rotate it. I polished the camshaft journals with a buffer wheel. I’ll see if I can find a high spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 21 minutes ago at 6:30am
Just keep turning it with penetrating oil while pulling it in/out. Use a speed handle or electric drill. Don't buff anything.
