1958 HD-5G into the fold: |
Page 123> |
Codger
Topic: 1958 HD-5G into the fold:Posted: 20 Dec 2025 at 4:49pm |
Widow is downsizing on retained possessions. I've known the tractor which is complete for a lot of years. However, it's not been ran in about six years. Engine is not frozen and I don't know about the steering clutches, but u/c appears to be in fair condition. It also has the bolt on grouser segments on top of the street pads. Story is the tractor was used to dig the basement to the house addition, and then put into the barn. There it remained not coming out till a couple of weeks ago to convert the parking space to a horse stall.
I'll haul it home after the first of the year when insurances go into effect for my tractor and trailer.
That's All Folks!
Les Kerf
Posted: 20 Dec 2025 at 8:12pm |
Sweet!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42285 |
Posted: 20 Dec 2025 at 11:08pm |
Last of the HD5 machines was 1955 ,
If you find the Serial # on dash plate or on the rear casting it can confirm the year built Lot of small changes over years of production , improvements to loader frame are some along with the 2 speed reverse transmission . With the loader pads without single grouser I dug many basements, put in drives, loaded many trucks and leveled many yards . Bought mine in 1972 and still have it , a 1955 HD5G - had 3 others 5G machines I sold and 1 HD5B from 1948 to 1955 machines |
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9005 |
Posted: 21 Dec 2025 at 9:43pm |
Ahhhh the sound of that 2-71 Detroit.....
Codger
Posted: 22 Dec 2025 at 10:19am |
I'll be over there later today and look for a data plate. She thought it was a 1958 build and seemed pretty certain, but obviously there could be disparity.
That's All Folks!
Coke-in-MN
Posted: 22 Dec 2025 at 11:16am |
Age of build can make some differences but overall interchange of any needed parts stays the same . Track , undercarriage , even full rear housing and components were used on the HD6 machines . Loader differed as did engine , but then the HD6 had updates also so from early first machines to last produced a lot of changes , the HD5 over the years just had small ones .
On the HD5G the big changes were in 2 speed reverse , 4 speed rather than 5speed , the loader frame front cross member going from box tube to round tube with welded brackets reinforcing round tube . pin length in upper fitment to loader frame |
Codger
Posted: 22 Dec 2025 at 2:42pm |
![]() ![]() ![]() All levers and handles operate smoothly with even spring tension behind them. She said it pulled very easy with the 4020 Deere tractor. I didn't sit in it so don't know about the transmission shifting but the hand clutch feels as it should. Drizzling out when the photos were taken and my phone shuts down on "humidity" constantly if out of the holder in this cool weather very long. I'm told the machine ran/operated well but was loud in a push......
That's All Folks!
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55341 |
Posted: 22 Dec 2025 at 3:33pm |
Some rather odd looking pads on the tracks, first time I've ever seen that. Any story behind it?
Edited by DiyDave - 22 Dec 2025 at 3:34pm |
Codger
Posted: 22 Dec 2025 at 7:12pm |
I've seen those pads in the past but been a lot of years ago.
Few more photos: ![]() ![]() ![]() Bucket cutting edge is broken out badly but I didn't snap a photo of it.
That's All Folks!
Coke-in-MN
Posted: 22 Dec 2025 at 10:17pm |
The Allis Chalmers HD5G with serial number 21073 was likely manufactured in 1954. The HD5 line was produced from 1946 to 1955, with a total of over 29,000 units built.
Coke-in-MN
Posted: 22 Dec 2025 at 10:21pm |
This is the counterweights on my HD5G - something I notice you are missing . Careful when using bucket as overloading machine without some counterweight will overload front idler axle and wheel bearings - Had 3 front idlers all with bent axles from machines I worked on and sold Edited by Coke-in-MN - 22 Dec 2025 at 10:24pm |
Coke-in-MN
Posted: 22 Dec 2025 at 10:29pm |
HD5G 26784 1955 I bought it in 1972 and still have it
Codger
Posted: 23 Dec 2025 at 4:38am |
Thanks Coke. No idea to any of this myself. Looks like it's been a long time, (if ever) this machine had counterweights installed. Those on your machine appear to be cast iron/steel composition. If the machine proves serviceable when it's back at the shop, I'll give it a good pressure washing and remove the tracks to evaluate u/c further, and fully. It looks fair setting there with plenty of adjustment left, and there was no mention of any track walking off, but I'd like to evaluate the front idlers, bearings, etc. before pressing it into any kind of service as it will be kept several miles distant from the shop.
I did snap this but neglected to post earlier. No idea if it reveals anything to the discerning eye or not:
That's All Folks!
wjohn
Posted: 23 Dec 2025 at 7:42pm |
Are you planning on shoving it onto your trailer or trying to get it running where it sits?
Codger
Posted: 25 Dec 2025 at 5:48pm |
Most likely I'll winch it up onto the trailer and use the shop gantry to install a 4D battery. Getting too old to hike those up onto my shoulder any longer.....
Engine is not frozen as I can pull it around by hand. Hopefully no stuck injectors but will find out soon enough.
That's All Folks!
Coke-in-MN
Posted: 06 Jan 2026 at 11:25am |
I use a single 12V battery in mine , a 800 AH automotive battery , that I also use in pickkup snow plowing truck .
Changed out starter to M42 late Delco starter with solonoid so have a key switch start now . Also changed out generator and now using 1OSI automotive alternator single wire hookup by changing front pulley that I machined to take a B width belt . One problem that shows up is sloppy shift lever when the internal parts on lever wear . it's a easy fix by replacing the side bolts in tower and the cross pin along with the round tube the pin and bolts fit into . |
Codger
Posted: 07 Jan 2026 at 7:43pm |
I have both 4D, and 31 threaded posts at the shop. I swapped the 11B over to group 31 top post types as that engine readily fires in the coldest of weather. I agree the 10SI is the way to go and the types that pull in at 1000rpm seem to be pretty reliable. Have a couple of 2600 L-N that are fresh from the rebuild shop and not used, but that is a larger frame than the 10SI. I've not been back over there since Christmas Eve so don't know fitment requirements. Regardless, it will be converted to a one wire, (or self exciting) setup. Gear selector felt quite tight in the rails, and gates so hopefully won't require any work but you never know till it's operated.
That's All Folks!
Les Kerf
Posted: 08 Jan 2026 at 6:23am |
The 2-71 DD in my Son-in-law's HD5G has a twin belt drive; I removed the pulley from the generator and put it on a Delco one-wire 10SI alternator, then modified the mounting to suit. His gear shifter was quite sloppy, I posted a thread about rebuilding it several years ago.
Codger
Posted: 08 Jan 2026 at 7:15am |
Thanks guys. I should be over there this afternoon and I'll look a bit closer at the existing setup. Lost the alternator on my air compressor yesterday it seems as it won't pull in any longer. Napa supplied 10SI "one wire" setup that is about four years old. It has always been very slow to pull in but once engaged, seemed to work fine.
That's All Folks!
Codger
Posted: 08 Jan 2026 at 7:48am |
Went ahead and picked up a low rpm pickup 10SI One wire 105A alternator from Amazon this morning. Ebay had the conversion sheave for a 3/4" drive belt so went ahead and ordered that also. Both offer free returns so no real risk.
That's All Folks!
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4885 |
Posted: 08 Jan 2026 at 10:57am |
I did like Les and took the pully off the generator. It fit the Delco alienator with no modification.
Coke-in-MN
Posted: 08 Jan 2026 at 3:23pm |
I took the pulley from a alternator off a 70 series GMC that was double belt , then put in lathe and widened groves to accept the B width belts , so still running 2 belts
Codger
Posted: 09 Jan 2026 at 11:00am |
Was over there yesterday in the rain and the generator with two belts is still in place. Definitely B series belts so if that sheave will fit I'll reutilize it.
Need to pull the starter from my old TLB this afternoon and send it in for rebuild as it will crank engine about three seconds and then start getting really warm and cranking ceases. It still tries but is extremely labored. Engine is a 3-53 Detroit and usually starts easily.
That's All Folks!
Les Kerf
Posted: 09 Jan 2026 at 10:48pm |
The twin belt sheave fit right on my 10SI unit perfectly and I re-used the belts as well, you will need to get a bit creative with mounting it
Codger
Posted: 10 Jan 2026 at 6:02am |
It was raining and my phone is very susceptible to shutting down when moisture is detected so only snapped this photo: ![]() Also grabbed the gear selector handle and it is quite tight in operation. I expect this area has been addressed in the past as the deceased was quite mechanically inclined from what I gather. I'm told the tractor should be usable once started again. After reading Les's post on the sheave fitting the 10SI series the order on ebay for the conversion sheave was cancelled. It had not shipped yet so no problems there. If this generator works however, I may not replace it till later, or problematic. I should have the replacement alternator on Tuesday for the air compressor and I do remember reutilizing the original dual belt drive sheave from it's Delco generator all those years ago. It however is automotive sized belts about 1/2" in width. This photo(s) are right after that conversion and first runup before swapping wires on the ammeter: ![]() Edited by Codger - 10 Jan 2026 at 6:50am |
That's All Folks!
Codger
Posted: 10 Jan 2026 at 7:37am |
I'll just build onto this thread with a starter problem. I did remove the 30MT starter from my Detroit engine and it is burnt internally. It was dropped at a local rebuilder who estimates $175, to $325 for a complete rebuild once opened up. Don't mind doing that if need be but my question is: Is there a modern gear reduction unit that is lighter in weight and draws less current available, and should I even look this route? Starter is 12 tooth CW rotation, 12VDC. No photos as raining when starter was removed and phone was purposely left in truck.
That's All Folks!
Les Kerf
Posted: 10 Jan 2026 at 8:03am |
The generator that was on my Son-in-law's HD5G is a Delco-Remy third brush type that uses the third brush for current (amps) limiting but has a two-coil regulator for voltage regulation. The previous owner told us that the generator did not work, and he was correct, so I swapped it out for the 10SI alternator, which I do not regret. I later checked out the generator on the bench and found that the regulator was not making ground contact, when properly grounded it produced voltage while being spun with a drill. I did not give it a full workout at the time but I plan to when I get my test bench set up. Your generator appears to be a different type and has what might be a three-coil regulator, is it possibly a Prestolite? If it functions properly I would just run it.
Les Kerf
Posted: 10 Jan 2026 at 8:13am |
We put a 39MT starter in this HD5G, it is leaps and bounds better than the original. I just smile every time I hear that 2-71 fire up ![]() |
Codger
Thanks(1)
Posted: 10 Jan 2026 at 6:50pm |
We are in the minority but I too like the old "two stroke joke". Just started one of my old semi tractors yesterday with 6V-92TA power and just kinda smile while warming it. I like the noise which isn't as loud as it used to be with my age......
I've installed several 39MT starters replacing original 40MT series, but they've always been on semi trucks. I'll look into a reman unit online as really would rather this than a new overseas produced. Space is kind of constrained on this TLB, but I'll have to garner some actual dimensions if this original 30MT is cost prohibitive to go forward with.
![]() Edited by Codger - 10 Jan 2026 at 6:53pm |
That's All Folks!
Codger
Posted: 11 Jan 2026 at 5:20am |
Alternator for my air compressor now shows arriving today? Was originally scheduled for Wednesday, then Tuesday, and now Sunday. I don't have "Prime" or anything special so this is surprising, but welcome.
That's All Folks!
Page 123> |
