8 foot disk additional weight ?
Pointer Hollow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Topic: 8 foot disk additional weight ?
    Posted: 26 Dec 2025 at 6:26pm
On this disk someone has welded two bolts on the frame (a set on each half), I assume to add weight to the disk.  I was thinking about adding some weight and I have some wheel weights.  The weights I have weigh about 140#'s each.  Would it be too much to add the extra 140#'s to each side or would that be too much for the bearings, etc.
I was debatiing on doing that or adding one 140# weight in the center of the disk.
Thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2025 at 9:01pm
Common addition of weight locally is a rail road tie cut to length. Haven’t seen them cause any issues.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 6:27am
Probably the bigger problem you'll run into is keeping the front-end on the ground.  Too much weight and picking the disc up could be a problem too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 7:15am
I just added 300 pounds in weight to the front.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 7:34am
If its not cutting enough a pull type (drawbar hitch) disc is the way to go,they will cut better and you can add all the wieght you can pull no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:49am
If you've got some wheel weights laying around throw them on and give it a try.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:07am
Gary is one of the smart guys on this site and he does bring up an important point. The snap coupler disk is more of a finishing disk than a primary tillage implement. I have one, with new blades on it, and it works great for incorporating pre emerge herbacide. But if you want to follow your moldboard plow, especially if the ground has a lot of clay or residue, you are going to be disappointed. You can take multiple passes but that just wastes fuel and increases soil compaction. Its also not great at leveling a field. If you are just doing an acre or two, you can muddle through, but any more, look for a pull type disk.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:21am
+3 These are pretty lightweight disks. I got one with the intent of using it for fast/shallow last pass tillage to kill small weeds right before planting. I have an IH 470 disk for more severe tillage. You can certainly add as much weight to your mounted disk as your tractor can handle and keep the front end on the ground but I think you will reach that limit very quickly even with your added weights up front.
However if you have pretty sandy soil you might be okay?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:14am
Ok, we will give it a try!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:33am
Yours looks like it has OEM blades which do pretty good even without weight. Many like mine have aftermarket blades which have too much "cup" and just won't cut well. An uncle had a "10 blade" snap coupler T bar hitch wheel disc. It would chop the crap out of cornstalks and give the WD With M&W's a workout without extra weight. You needed the TB working. Your results may vary.
dr p View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:20pm
The other concern i would have is if you start adding weight to the disk is the added stress to snap coupler hitch. If that spring fails, the tougue of the disk could dig into the ground and if the latches don't release, that disk is going to be on your head. At least put an "oh sh!t" chain on it
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 8 minutes ago at 7:09pm
Not as likely as a plow with rigid arms doing that, but still a good practice...Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 56 minutes ago at 7:21pm
Thank you all for the information.  I will keep you posted how I make out.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 34 minutes ago at 9:43pm
I know you have a safety chain on the plows. You might want to put one on your disc as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 27 minutes ago at 9:50pm
I will do that!
