460 loader control valve options
farmtechguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Topic: 460 loader control valve options
    Posted: 6 hours 35 minutes ago at 10:36am
Greetings,
I acquired a 160 diesel with (I believe) an OEM 460 loader the other day. After using the loader a bit it's apparent I have an internal hydraulic leak as the bucket slowly sinks with a load in it.
I'm inclined to think it's in the control valve. When I go to lift the bucket, if I only open the valve ever so slightly, the loader drops. Once I open the valve enough, it lifts just fine.
My question is: couldn't I just replace the valve with a cheaper universal spool valve from ebay? I'm sure the cylinders could use a seal job as well.
Your input is much appreciated!
Edited by farmtechguy - 6 hours 33 minutes ago at 10:38am
ac160 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 42 minutes ago at 11:29am
Try changing the packing in the cylinders first.  I have a 460 loader on a 6070 that leaked down with or without a load, and new packing solved that issue.   There were two versions of the 460 loader, one for a 160 and the other for the 6060 - 6080.
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 3 minutes ago at 1:08pm
I would agree start with the cylinders first. But there is a no tools required way to check. When you first start the tractor run the loader up and let it leak down a number of times. As it is lowering put your hand on it, the bypassing oil will create heat. If you cannot feel any warming of the cylinder, then the valve is your leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 18 minutes ago at 1:53pm
Thanks for the replies. I picked up a 4x5 round bale and definitely have gland seal leaks on two of the cylinders. I'll do the test you describe here in a little bit and report back.
Do you guys think an internal cylinder leak could be the cause of the "dead" spot when opening the control valves? It's pretty bad when I it loaded up.
