Allis c adjustable tie rod
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Allis c adjustable tie rod
    Posted: 6 hours 45 minutes ago at 1:52pm
So the original tie rod is not adjustable to correct steering full left and right. I’ve taken the front spindle on and off several times in effort to correct. I’m thinking of making my own tie rod and installing new ends. Both ends will be right hand threads just so I can get equal left to right steering. Once set doubtful it will ever need adjusted. Am on the right track ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 31 minutes ago at 3:06pm
have you determined what is WRONG with the original tie rod and why a new one would FIX the problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 51 minutes ago at 4:46pm
I walked away for a while and came back and it lined up. I’ll take it.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 23 minutes ago at 5:14pm
the drag link is not  adjusable but the right and left tie rods are ajustable  unless some one has cobbled somting up over the years
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 52 minutes ago at 5:45pm
Narrow front so only one tie rod. My disappointment to see the sector shaft on front spindle never had a bronze bushing. I packed with grease and drilled and added zerk fittings on steer box and front spindle. I’m not trusting oil won’t run out coating front wheels etc. I can’t be the only one to switch from oil to grease.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 42 minutes ago at 5:55pm
Dan, i think the teminology has effected the posts we gave..  The NARROW front had no "tie rods"... those go from the gear box steering arm to EACH WHEEL.. On a narrow front, there is only one rod going from the front gear box to the gear box under the gas tank. AS HUD said, ALLIS calls that a "drag link" and it was a fixed length.... and YES, the front end part wear and regular oil will leak out.. Some use corn head grease and some use tube grease as the "fix".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 50 minutes ago at 6:47pm
Yes you are correct. In my mind I was thinking an adjustable rod was needed. Always value this site for this rebuild thanks.
