Styled 1949 Allis WF
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: Styled 1949 Allis WF
    Posted: 20 Nov 2025 at 5:39pm
On the WF is there a muffler under the hood with a short pipe running threw the hood the hole on the hood is to small for a muffler some images online show a short pipe or was it just a strait pipe I really do not want to cut the hood for the muffler the exhaust was missing when I bought the tractor and head removed
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:26pm
The neck of the muffler goes through the hole in the hood from the top. There's not enough room for a muffler under the hood. I have seen drawings in manuals with just a short pipe without a muffler. This way you end up inhaling more exhaust than comfort allows.  The noise may be amusing for short running but not pleasant for a whole day's work in the field. My WF mufflers probably average 2 1/2' in height. The hole in the hood is big enough for the right size pipe. On the WD models with the same engine they made the hole in the hood bigger even though the exhaust goes straight up like on the WF's.
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:37pm
at one time you could get a nelson under hood muffler
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:45pm
Yes from factory had underhood muffler same as WC
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 7:15pm
My 1949 WF has a under the hood muffler with a strait pipe.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 9:59pm
The first WF we had was a kerosene model and they never had a muffler under the hood as the exhaust came out of the side of the manifold at about a 45 degree angle with no hole at all in the hood for exhaust. With the one gallon gasoline tank under the hood, less than two feet away, it would have been crazy to have an under the hood muffler. Using the belt pulley to run the thrashing machine the manifold turned red from heat, to collect more heat in a muffler under the hood would make no sense, let alone to evaporate whatever gas that was left in the small tank.
This page was generated in 0.152 seconds.
