D 15 road draft tube
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 road draft tube
    Posted: 21 Oct 2025 at 7:07pm
When I got my D 15 (gas engine) it had one, which I replaced with a regular breather/oil fill. Just wondering if this was O.E. Anyone know? It's a 1961 . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 9:54pm
Early D-15's prior to s/n 9001 had an oil fill/breather cap like a D-17 did with no road draft tube. Effective with s/n 9001 (series 2) the valve cover was different and the oil fill cap was a 1/2 turn twist to remove or install and had to have a road draft tube because it sealed up tight. What you have/had, I have no idea.
Edited by DrAllis - 21 Oct 2025 at 11:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 4:46am
Thanks Dr Allis. My tractor is 4065 I think? I just came across the draft tube in the shop and thought I'd ask about it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 6:21am
If you have the correct valve cover (by s/n) there isn't any place to even connect a blow-by tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 6:34am
It came out of the top where the oil fill/breather goes. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 7:41am
Sounds homemade to me. A hose that connects to where the breather/fill cap goes sounds like something I would have done to keep oil from splattering on spark plug wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 7:42am
if you have an old engine with excessive blowby... it was not uncommon to put a draft tube on to keep the oily mess shooting toward the ground and keep it off the engine block and valve cover..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 8:03am
Sounds about right. Thanks Dr Allis and Steve
