Clutch Safety Switch AC6080 2WD
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Safety Switch AC6080 2WD
    Posted: 14 Sep 2025 at 4:19pm
Can anyone tell me where the Clutch Safety Switch is located on an AC6080 2WD?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2025 at 4:50pm
Remove the black panel down by you feet. Maybe about 8 metric bolts to remove. It's in there. If it won't crank over, there are a couple of PTO safety switches that can also cause that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2025 at 8:21pm
It’s a real pain to get to it so be prepared. The pto switches are on the right side of the transmission below the pto disconnect lever. There are 2 of those. All 3 switches are the same type. Make sure you get them adjusted correctly or you will damage the switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2025 at 12:54pm
There's more to it. Of the two switches on the right hand side, one of them is for the engine cranking circuit. The other one, just turns the light on in the dash. There's a second PTO safety switch for engine cranking on the left-hand side, below the seasonal disconnect lever. At least one of the levers has to be in a disconnect position before the engine will turn over. Between the switches, wiring connections, and voltage drop in the harnesses, it can cause a low voltage problem at the starter solenoid. An auxiliary slave solenoid or relay can help to make sure that you're getting a solid 12 volts to the white wire on the starter solenoid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2025 at 9:35pm
Forgot about that one Lynn, good catch. Haven’t had an issue with it yet.
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 6:45pm
Usually if I press the Clutch Pedal 3 or 4 times it will crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 8:02pm
If that's the case it may just be out of adjustment. Locking nut may have backed off. Ours started that way but eventually replaced it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 9:30pm
Does it make a click noise at the starter every time, even if it won't crank over? You can bypass the clutch safety switch with a jumper wire to see if that makes the starter engage every time.
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 10:20am
Its been awhile since I am able to respond, but I appreciate ever ones input. Yes it does make  a click noise every time. I have had the starter kick in even when the clutch is not depressed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 27 minutes ago at 10:34am
Sounds like the contacts inside the starter solenoid are getting bad.
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 29 minutes ago at 7:32pm
Is there any possibility that it is the ignition switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 51 minutes ago at 11:10pm
The ignition switch is of course a possibility, but not in my opinion. It certainly sounds like you are getting a signal to the starter from the key switch and other safety switches, plus the harness. This can be easily checked with a simple test light. The white wire on the solenoid should be powered up every time you try to crank it over. Even if it lights up, that won't tell you how much voltage the white wire is receiving. You'll need a volt meter for that. You can further test it by jumping that small terminal with the white wire to the large terminal with the battery cable. A screwdriver or anything metallic will work. BE ADVISED, DO NOT DO THIS WITHOUT THE TRANSMISSION IN NEUTRAL, APPLY THE PARK BRAKE AND LEAVE THE KEY IN THE OFF POSITION. You don't need the key on to do this test and you don't want the engine to start anyway. If the engine cranks when doing this, then you're probably getting a low voltage signal from the white wire. A simple relay should fix that. The starter could also need a new solenoid, have poor connections at the starter, or even be extremely dry inside the starter. Probably a lucas starter, so be sure to look over the connections at the solenoid and the little strap from the solenoid to the starter case. If you don't know how to do these things, then it might be best to get some outside help. We don't want anyone getting run over by an unwanted startup.
