Model B belt pulley seal
Freewheeling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheeling Quote  Post ReplyReply Direct Link To This Post Topic: Model B belt pulley seal
    Posted: 18 Sep 2025 at 3:34pm
I replaced the old felt oil seal with a CR 13865 single lip rubber seal.  The shaft doesn't have oil grooves. The shaft looked good but I polished it with 400 grit and finsihed with 600 JIC. It leaks.  Any ideas why?  Is there a felt seal available anymore or do I have to speedi sleeve. It looks like the SKF 99138 will work. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2025 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheeling Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 1:20pm
Thanks.  Was still able to get the leather version from AGCO. $30 non-returnable.
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheeling Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2025 at 3:28pm
Mike-
FYI  Picked up the new AGCO seal. The guy who placed the order got it wrong. AGCO # 70207993  has been replaced with 70225450 which is actually  CR-132865 , a single lip nitrile rubber. It's the same seal I have that leaks. Guess I have to speedi sleeve the  shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2025 at 7:42pm
I figured the leather seal would supersede to newer lip seal.
I was wondering the part in parentheses (for shafts w/return oil groove)
