49 wd hydraulic pump pressure |
G226WD
Topic: 49 wd hydraulic pump pressurePosted: 10 Sep 2025 at 3:18pm |
Hi everyone say ive got a 49 wd the pump has been in a cardboard box for a few years and I put it back on just recently pump says 1800psi then 1500psi then now its 1000psi i replaced the long small spring the one for high pressure the old one made the pump chatter when i engage it id like to know about the shims on the top as well i want to get just under 3000psi if i can need a little help thanks
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3108 |
Posted: 10 Sep 2025 at 4:21pm |
Get a WD or WD45 service manual. It explains the pump very well. I rebuilt mine about 12 years ago.
You need to pull out all 4 of the check valves on top and make sure the springs are good. I think 2 of mine were wore through and I replaced them all and also reseated the balls into the seat. Once that is done and all your orings are replaced. Then you can see where your pressure is at and start adding shims to the unload valve if needed. |
G226WD
Posted: 10 Sep 2025 at 5:02pm |
can i do this while the pump is on the tractor also where in the pump are the orings you are refering to.
i have some parts and pieces for the pump here havent had it mind in pieces in a while part numbers would help i do not have a service manual thank you
G226WD
Posted: 10 Sep 2025 at 7:16pm |
is this what your talking about? part no 70224670 ?
Allis dave
Posted: 11 Sep 2025 at 5:55am |
To fix everything in the pump you need to remove it. You can check and replace the 4 check valve plungers that go in the top while the pump is on the tractor. Before doing much you should go on ebay and by a service manual. It will be 20 well spent.
I don't remember all the details or part numbers now. |
