Bowed front axle WD/WD45
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Bowed front axle WD/WD45
    Posted: 08 Aug 2025 at 9:15am
I just bought a wide front at an auction with the center channel slightly bent. Any suggestions on how I might bend it back. Will a good size press to it? My press is too narrow but was thinking of using a 20 ton jack, an HD11 dozer and some steel plates and blocks. Another thought was to cut the curved braces off and then straighten then weld back together. Second option doesn't look easy. Anyone else have success straightening one? Thanks
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 9:17am
Bent downward in the center ?? from an overload with the wheel tread set wide ??
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 9:23am
Yes that's what it looks like.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 9:25am
The axles weren't set wide when I bought it. Just one hole showing and with some snoose juice and some tapping with a maul they came out. Wasn't bad to get them out.
Edited by Lonn - 08 Aug 2025 at 9:26am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 9:41am
Chain it down out by the spindles on your trailer and use a 20 ton jack at the point it looks to be bent down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 10:43am
To add to that, I'd have a 1" thick plate about 6 inches square to place between the bottle jack screw and the axle tube and see how close you can get it back to straight. To finish one might be down to 3 inches long to over bend it so it can spring back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 11:48am
Isn't that a tube with the bottom partially cut out? Might want to tack a couple chunks over the slot to keep it somewhat square whe bending back. The metal is stretched so I doubt you can straiten it well. My opinion....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 12:36pm
Thanks folks I'll take all the advise into account and let you all know how it goes.
Wink
I am a Russian Bot
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 4:29pm
Another idea, do you have a friend that has a body shop? Frame straightener can true it up. Seen it done.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 5:46pm
https://www.facebook.com/share/p/16x8P5DedR/
Edited by Lonn - 08 Aug 2025 at 6:31pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 5:50pm
Heated to about 200 F just to relieve the metal.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 6:31pm
Link didn't go to my fb page so hopefully now it does
Nope still doesn't
I can't post pics from my phone.... says file size is too large
Edited by Lonn - 08 Aug 2025 at 6:34pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 8:54pm
[IMG]uploads/1103/20250808_1632
Edited by Lonn - 08 Aug 2025 at 8:57pm
Wink
I am a Russian Bot
