Any sickle mower experts out there?
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Topic: Any sickle mower experts out there?
    Posted: 03 Aug 2025 at 4:32pm
For those that remember, the D15 I'm running was a barn find from across the road. Sat there for 20 years before I took it on. Less known was it was also hooked to a JD 450 pull type sickle bar mower for all those years too. Now have that out and am attempting to revive it too. I have some experience with that type of mower as I ran one mowing hay with them when I was a kid.
Anyway, fixed both flat tires, greased it up, hooked it up to the D15 and gave it a whirl. It actually worked. Condition of sickle (they call it a knife) is marginal. Needs to be sharpened at minimum, but also concluded it needed all new guards, some of which bent pretty far from hitting something. Looked like maybe half might have been the originals, then 3 or 4 other miss matched brands. They all have two things in common.......flat worn out and sickle sections rested on the ledgers as they are supposed to.
Turns out the ledgers can all be replaced, and started with that plan, except you can't buy those and if you could, cost as much as new guards. Aftermarket guards show up in parts books, but iffy supply and if you could find them almost as much as actual JD, so JD it was. Ordered 33 of them and not cheap. Have now put them on and all of them also have two things in common.......they are all new and none of them fit right. There is a gap of as much as 3/16 of an inch between guard ledger and sickle sections and those two have to touch to work right. I see no way to adjust these to fit.
Anybody familiar with these at all?
Old guard that fits perfect.
New correct guard that doesn't fit at all.........
Edited by modirt - 03 Aug 2025 at 4:44pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 6:24pm
You don't mention hold down clips, are there any on your mower.  They are to keep knife sections real near the ledger plate to that part of the guard.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:52pm
Have to agree, check your hold downs, they wear to or get bent.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:59pm
Those guards are made of malleable iron and can be bent to close the gap to the section.  There is a special tool that you use for that ; works sort of like a special anvil,  and once it is placed properly you hit the section with a hammer to bend it.
Edited by Alberta Phil - 03 Aug 2025 at 8:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 4:57am
Hold downs, wear pads and guards all have to be right.  Not familiar with JD, but on Allis mowers, the standard hold down clearance was a postcard or match book. Lead matters, as well as the tipping angle of the bar.  I'd invest in a manual for the mower in question first and read it...
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 7:47am
You mentioned some guards were bent, more that likely ‘bent up’ that can also warp the sickle, if possible pull the sickle out, and lay on a flat concrete floor so you can see if the sickle itself is warped. Aldo then is a good time to check the sickle ‘bar’ for warp, if that is warped too much, you will the fight the problem you have forever, until you get the bar back to original ‘trueness’ as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 8:00am
Was looking at the wear plates and hold downs and likely all would benefit from replacement. But something else is wrong with those guards. They bolt up at an entirely different angle. And they are made heavy enough there is not bending of them. Not like the New Holland guards shown in the video (which btw was one of most informative and annoying videos ever. More google ads imbedded than video content).
And this sickle knife uses rivets. Not enough room under the hold downs for the bolt on sections to pass under. I have the special V shaped grinder wheel used to grind these. No need to replace them all the time. The underserrated sections can be sharpened many times. Do not have the rivets however. I asked JD and don't think they had them either.
And do have a copy of owner's manual and parts book. Parts number for the guards is right. Both in the book and on the guards.
I found that All States Ag Parts has a guard that fits JD 350 and replaces same parts number. Have one ordered to see if they are a match for new or old.
For most mowing tasks, these days there are better options. Disc mowers, brush hogs, etc. For hay, even the old but related New Holland Haybine is better. But for some things......they do come in handy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 12:37pm
I have an old sickle from about 1940 that i got for FREE about 20 years ago. I have it belly mounted on a B Allis tractor.. I have run into the same things your seeing . Originally had rivets, but i put new blades on with  bolts, then cut any left over off flush with the nuts.. The hold downs are close on a couple of them, but do have room. Have also had aftermarket guards that dont seem to fit very well. I have used a body grinder to  grind the mounting face at a small angle so them tip up and get closer to the knifes....  YEA.. its 85 years old !!  Got some problems, but i only use it 2-3 times a year for 2 hours to do the road sides and ditches... Sure wish it was different / newer / better... but cant justify anything else for minimal use... Sure wish it would TILT so i could trim the brush / weeds on a sloped road side !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 1:08pm
I have a "Sickle Service" rivet tool that will allow you to re-rivet new sections to a complete knife faster than you can round up the wrenches to replace the bolt in sections.
  Yes, you can replace the bolt in sections without removing the knife, but if you have everything in good working order the biggest problem of pulling a knife is to be sure all your fingers are not in the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 5:25pm
Update.........After a lot of looking and poking, problem seems to be new guards were not made right for this mower. Guards bolt to underside of the bar and there is a T wing that holds guard in right position to bolt up. This T has what amounts to a claw to hold it in place. The "claw" on the new guards being 3/16" to 1/4" high. Old guards not much more than 1/8". The claw on new guards then projects upwards high enough that the bar part of the sickle rides on it, preventing sickle from dropping far enough to reach the wear plates on back side, and ledgers of the guards on the front.
Am up to no less that 5 different guard options from various sources and only one option (one of three options) from John Deere is even remotely close to fitting right. Right now, all the old guards back on.
Did a test cut and found one more critical missing part out on the end.......ledger plate missing. Mower won't go 20 feet before plugging on the end. New part ordered. Stay tuned!
PS: Cheap aftermarket option guards that don't work run $10 each. JD guards that don't work $15 each. JD Guards that do work $18 each. Needs 33 of them. Ouch.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 8:41pm
How thick is the host bat for the guard?  5/8 or 3/4. Ac used both depending on the year. The new guard may be for the thick bar and you have the thin one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 9:07pm
I think that is the gist of it. Old guards project flush with the front of the bar. New guards project above flush. Nothing you can find to buy today matches the old guards exactly. Some of them not even close.
From what little I could tell from short test, going to be critical to get good guards and a sharp sickle. Lots of drag and strain on the entire bar as is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 10:29pm
I have that problem with the mower on my B.... It has the ledger, but not the wood board.. I think on road ways where your cutting WET/ GREEN/ EVERYTHING, this might be a fact of life... I can go 4-500 ft before having to stop and backup to DUMP the PLUG off the end... Not the same as cutting dry wheat or straw ??
