Allis chalmers 160 power steering
Peek1974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peek1974 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 160 power steering
    Posted: 13 Jul 2025 at 2:09pm
My allis chalmers 160 power steering pump keeps blowing seal I brought a another pump and it does same thing any suggestions on this
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:57am
Rare, but suggest checking the return off the relief that Tees into the suction. A blockage here will over pressure the seal when the relief acts. When in normal running there is a small hole from the suction side to the brg section that keeps pressure from the seal from normal lube leakage on the shafts; this is designed into most pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 7:05pm
That pump is a bear to get to and to replace a belt. Sure doesn’t have much room for belt adjustment, probably the one downfall I have with the tractor. I have a leak I need to find, I had to add fluid to mine this year during hay season. Is the tee at the pump that you are referring to? Otherwise the power steering is really good on these tractors.
This page was generated in 0.143 seconds.
