D-14 not starting after running
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 not starting after running
    Posted: 04 Jan 2011 at 8:27pm
We have some issues with our D-14. Have to tear it apart again to REPLACE already replaces front and back seals on the crank..It leask terribly for some reason. Also...We overhauled the engine...the tractor starts cold just fine...but after it runs and you turn it off and attempt to restart it......It won't turn over fast enough to start. Very Very Very sluggish.( it's 6 volt ) What could be causing this? Is the starter tired?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 8:34pm
Got the proper size battery cables? For 6V, you need a minimum of 02 gauge with 00 gauge being best. If you have typical automotive replacement cables they are in the 4 to 6 gauge range. They work fine with 12V, but with 6V, you have half the voltage so you need twice the amps to do the same work. Twice the amps need thicker cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 8:48pm
I will have to check it out...It kinda cranks slowly all the time...but it always starts when it is cold.
"Better By Design"
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:01pm
when you installed the seals did you use speedi sleeves? Sometimes the sealing surface gets a groove worn into it and the seal doesn't seal. You also have to use them on the older engines that had a spiral cut in the shaft. Bob
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:19pm
I would double check the timing, I believe the timing is not correct when it starts like that
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:43pm
Timing was the first thing we checked...everything we tried never seemed to help
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:47pm
do they have Speedi Sleeves for the size for the big rear main?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 9:45pm
Austin. Yes they do have a speedi sleeve for the rear main at NAPA. Bob
This page was generated in 0.576 seconds.
