AC 840 WHEELED LOADER TRANSMISSION |
WELJ31
Joined: 13 Apr 2025 Location: LEWISTON MI Points: 7 |
Topic: AC 840 WHEELED LOADER TRANSMISSIONPosted: 13 Apr 2025 at 9:12am |
Hello
I live in northern MI where ice storm just hit. We are trying to get clean up going and ran into a problem.
I did a search and found nothing. So I am iso information on a older AC 840 wheeled loader. Should be basic information. I have the operator , service and parts manuals but cant figure this out. The pics in my manual are not clear. I was trying to check the trans fluid level. The trans pan has two pipe plugs on the front. One high and one low. My understanding was to pull the top plug to check fluid level. Well that resulted in about 2-3 gallons of ATF coming out all at once. 1) Is this actually how to check the level? Manual states open valves ??? I have no idea what that means. but pic has a caption saying plug? 2) Manual says Dextron fluid? ![]() Thanks for any help |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4767 |
Posted: 13 Apr 2025 at 7:10pm |
I am not familiar with your loader, but it was very common to not have dip stick until the 1960's.
I have mid 1950's AC crawler that you pull a plug on, the next size larger crawler built at the same time has a dip stick. I wonder if they meant a bolt like plug that has been drilled so turn it out just several turns and it can drip out just enough to say it has fluid. You never turn them so the threads are all the way out of body. John Deere used that kind of thing on the 2 cylinder Jonny Poppers. I know very poor description. Hopefully jog someone's memory and they will have a name other than valve.
Brad in WA
Bronze Level Access
Joined: 29 Sep 2009 Location: Lynden,WA Points: 199 |
Posted: 13 Apr 2025 at 10:23pm |
John, I've had an 840 loader for 30 years. Yes the oil level should be to the top check plug. If yours was overfull it's possible either the steering or loader hydraulic pump is leaking hydraulic oil into the transmission, thru the front seal. I had this years ago, putting a new seal on the steering pump solved the problem. It's the same seal as a 190 tractor. Be carefull when you slide the pump out not to drop the adapter drive sleeve into the tranny. Hope this helps.
WELJ31
Posted: 14 Apr 2025 at 8:39am |
Thank you that appears to answer my questions.
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 150 |
Posted: 14 Apr 2025 at 6:49pm |
Just out of curiosity is the transmission oil to be checked hot or cold and engine running or stopped?
WELJ31
Posted: 15 Apr 2025 at 3:06am |
It was cold not up to temp. I know should have been running.
What type of fluid are you using? Manual says Dextron atf |
WELJ31
Posted: 15 Apr 2025 at 6:44am |
what type of fluid are you running?
Brad in WA
Bronze Level Access
Posted: 15 Apr 2025 at 7:59am |
I know the manual says Dexron ATF, but I've been using a good hydraulic oil. Check with engine idling.
WELJ31
Posted: 15 Apr 2025 at 8:03am |
I really appreciate the help
So if its leaking hydro fluid into trans is there any danger to the trans?
Brad in WA
Bronze Level Access
Posted: 16 Apr 2025 at 3:50am |
I don't think a little overfull would matter but I wouldn't let it get too full.
WELJ31
Posted: 19 Jun 2025 at 8:38am |
How big of a job is that (seal) and will it harm the trans if not fixed right away? thanks
