3 point hitch stays up
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Topic: 3 point hitch stays up
    Posted: 17 Jun 2025 at 12:19pm
Hello,
I have a 7000 maroon belly with an issue of the 3 point arms raising all the way when the tractor is running even though all levers are in the position to have them lower. When I turn off the tractor the arms go all the way down and then quickly raise when I start it back up.
When I push down (on what I believe is the pluger for the traction booster) it moves freely, but gives a sort of spitting sound and you can def feel it in the small line underneath it. Nothing changes with the arms when I push down on the plunger. I've attached a pic showing the plunger and the line. Thanks for your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 3:50pm
First thing I would do is get a manual, and go through the procedure for adjusting the TB linkage...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 4:47pm
Traction booster plunger must be UP/OUT as far as possible. There is probably rusted/stuck linkage holding it down, which raises the hitch.
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 12:01pm
Thank you for the reply's. I will take a look at the manual and verify!
