Hd6 fuel return lines. |
Primos75 ![]() Bronze Level ![]() Joined: 08 Aug 2022 Location: North carolina Points: 26 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jun 2025 at 7:19pm |
Hello gentleman, got another question. In this process of getting this thing rebuilt. I'm looking at the fuel line that return back to the pump from the injectors. Each connector has a rubber bushings on the flared end of the copper line. Those bushings are in real bad shape. Falling apart and can't be used. What do we replace them with? Is there new fittings we can use or who has any ideas? Thanks in advance.
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 1045 |
Is it the one with the injector on the head or the one with injector on the side
I believe it's a 6000 series. Injector at slight angle in top of head
I have the return line butall the rubber are no good on
Thanks, that's what I'm looking in to. Trying to find replacement rubber
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33963 |
Any Fuel Injection Shop will have those, Are typical on any Roosa Master or Bosch style return line. Just take a line with you and they will understand.
Out of curiosity what is the psi on the return line?
So long as Not Restricted, less than 5psi.
AC Mel ![]() Orange Level Access ![]() Joined: 23 Jan 2010 Location: N.Ca. Points: 1186 |
Assuming those are part number 70917806....They are available from Minparr...for $2.43 ea.. I just ordered 15 yesterday....for 2 sets of 11000 engines and some for spares.
Edited by AC Mel - 19 Jun 2025 at 10:11am |
