RC clutch pack fit b125 |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 953 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jun 2025 at 11:12pm |
Got a b125 power unit on a 60A combine and was wondering what engine and clutch parts would interchange with a RC?
Have a fellow member who has a nos RC clutch disk and pack and wondering if it would work on my b125? He also has an overhaul kit for a RC but pretty sure that will work. Thanks, Gavin |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21855 |
An "RC" actually had a "C" engine, not a "B", so it is a little more HP. The flywheel is larger in diameter to meet the starter, so I assume the clutch and pressure plate are different too.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5088 |
Funny that when an RC tractor was built, the model C did not exist. The engine used for the RC tractor (R code block) was a BE type block (which at that time was 116 CID) that was punched out to 125 CID, which at the beginning of the Model C production became the CE block that was now standard issue for all the B & C tractors. AS for the RC clutch disc, it has the 1-1/4" diameter WC center splines and is smaller than a WC disc , but larger in diameter than the B/C/P-U disc and is a unique part only used in the RC tractor. The RC flywheel is also a unique item that was only used in the RC tractor.
I should have been more accurate. The 1939 RC had what was to essentially become the "C" engine introduced in 1940. The 125 cube version of A-C's small block engine.
Edited by DrAllis - 05 Jun 2025 at 8:46am |
So the late RC would be the same?
I think my b125 is a later one… |
![]() ![]() Here is the RC one… The part number on the tag comes up as a for a C…. |
Is that number 70216965? the parts book shows that number to be a Rockford pressure plate not the Auburn pressure you have pictured. What is the diameter of the driving surface?
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2570 |
Just remembered, no clutch plate will interchange without some work. The RC used the smaller diameter B/C clutch, BUT used the WC spline center. You'd need to rivet the WC splines onto a C plate. Or find a clutch shop to redo your RC plate. AaronSEIA
Think it’s a 9” but have to confirm..
Measured original on b125 and it is 8.5” Original is absolutely shot due to rust. Half of the springs are rusted through. |
