LH/RH rolabar or V wheel rake?
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: LH/RH rolabar or V wheel rake?
    Posted: 23 Mar 2025 at 5:49am
Any opinions on which is better?  I've never used a wheel rake just a NH 56 rolabar.
I'm cutting around 40 acres for hay.  I have an old 14' swather that makes my windrows.  I've been using a NH 56 rolabar rake to combine 2 rows into 1.  Every so often I see a LH and RH rolabar come up for sale and I was thinking that would be nice to speed up raking.  I can rake pretty fast with the rolabar.  The old used LH and RH rolabars are kind of expensive compared to a wheel rake.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 7:05am
Wheel rakes are fast,cover wider swath if you get a v rake. The downside to wheel rakes is they gather dirt and small stones in with the hay as they follow the ground with more pressure. If you adjust them to less ground pressure then they leave hay. They also have a tendency to rope the window which can leave hay that didn't get dry. I traded my New Holland Rollabar Rake for a Rotary Rake. I know they are more money,but they do a fantastic job of raking. And you can rake early with less leaf loss because a Rotary Rake stands the window up so air can get through to dry the hay.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 8:22am
I grew up with the old roll bar rakes and whenever I see those rotary rakes run it looks like all the leaves get beat off the stems so you have stem bales. Watch the feed value disappear.
The wheel rakes are fragile. YouTube channel onelonelyfarmer did a couple of episodes on his wheel rake woes and was considering building his own to be more durable.
Get a demo unit for any proposed rake to run the same field conditions as your old rake and really compare hay quality side by side.
You might rake more acres in a day but if your bale-yield per acre drops plus nutrition drops then you are behind the game.
