Allis Chalmers 190 Gas Brakes
Caidyn Meyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Caidyn Meyer Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 190 Gas Brakes
    Posted: 22 Dec 2024 at 11:46pm
Every so often while in motion one side of the brakes likes to lock up. Any idea on what it could be?
Edited by Caidyn Meyer - 22 Dec 2024 at 11:47pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:08am
I think if you take the cover off and pull the disc out you will find your problem. Stretched spring,worn out ball ramps or broken brake material
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 1:08pm
Wear a mask when you remove the cover, the asbestos dust in there is harmful. Vacuum the dirt and dust before disassembling. The balls and ramps as said above are a common issue. Thankfully mine did not have flat spots worn in either. Installed new brakes and cleaned everything well and they work great. Not too bad of a job since they are external brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 3 minutes ago at 10:06am
When it locks up, it usually means it is time to replace the shoes and pads.
