CA Hydraulic Pump Not Functioning
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Pump Not Functioning
    Posted: 19 Sep 2024 at 12:44pm
Not even a hint of pumping, full fresh oil. Do I need to prime it? Not been operated in at least 30 years, probably 40. Piston noise sounds normalish if not a little louder than I remember. Things to check before I take it apart? I adjusted screws out against stops, disabled drawbar control by loosening adj screw and screwing lock screw into the housing, hold plate locked together.
I'm betting suction ball bearing stuck, rusted...
Edited by dfwallis - 19 Sep 2024 at 1:27pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 1:58pm
Ok, oil drained, delicate workbench cleaned, let the surgery begin:( I was hoping against hope, but not unexpected.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 2:50pm
Stuck piston, gobs o gunk in intake...suspiciously, one of the mounting bolts was loose.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 3:56pm
Clap  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 4:18pm
How do you unstick a fully depressed piston, nothing to grab onto, no back side access.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 4:30pm
is there a port 90 degrees to the side to blow air into the top of the piston ?   If air is not enough, maybe soak thru the port with  penetrating oil, then put a spoon full of oil thru the port and compress to build up psi ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 4:44pm
Check valve port inline, but none of the balls move. I haven't researched which direction they check
1952 CA13092
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 5:12pm
Assuming it's stuck because of gunk and not mechanical damage, I'd be inclined to throw it in either a heated parts washer* or ultrasonic tank to try and free things up. If it doesn't loosen the piston it at least ought to free up the check balls and allow you to use air.
I mention damage because of the loose bolt, hopeful someone didn't gouge it up trying to remove previously.
*A dishwasher, minus the salts, can suffice in a pinch. Just make sure to oil parts after drying to avoid flash corrosion, and DO NOT attempt if there's a chance of being busted in the act by the wife! Ours takes about 50 minutes including drying cycle.
Edited by ekjdm14 - 19 Sep 2024 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:26pm
Dad suggested tack weld to it
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:35pm
Omg, I kept tapping on it a little here and there now and then, and it popped up!!!!!! It appears to be just a very tiny amount of rust on the cylinder and piston.  Not bad at all, the spring is like new also.  Surprising that it was stuck that hard.  When it popped, it almost came completely out of the cylinder.
Edited by dfwallis - 19 Sep 2024 at 7:08pm
1952 CA13092
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 9:13pm
Wow, that is awesome! Agree and makes me think about being more careful with keeping the oil clean!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 9:47am
Some of what looked like rust is actually varnish/shellac. Comes off with goof off. Check balls removed by adding 80wt to the cylinder and tapping the piston a few times. All but one rusted/pitted on one side. Will replace all.
Edited by dfwallis - 20 Sep 2024 at 10:38am
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 6:39pm
I've finished reconditioning the pump and hold valve. All new check balls installed...the seats look to be in good condition. Tomorrow drawbar control and reassemble...fingers crossed...bad thing about being super rural is that both small town hardware stores don't stock ball bearings (balls)...ended up driving about 35 miles just for some silly 5/16 ball bearings.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 10:27am
The drawbar linkage plunger appears to have one complete spring and about 3/4 of a second spring intertwined...obviously that was intentional...what effect were they trying to achieve? Looks mostly pristine other than the plunger rod L shaped head pretty rusty...treating with rust reformer and ceramic paint.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 1:18pm
Whatever it's intention, the intertwined springs cause plunger fit and movement issues and risks scoring the cylinder wall so I'm returning to a single spring...now where'd that rectangular retaining clip fly off to ...
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 4:35pm
Attempted pump prime procedure. It seemed to be working. Kind of hard to pour into the inlet while manipulating the plungers but seem to be pumping. Reassembled and mounted the pump. Linkage, hoses, and refill oil next, then...dun dun dun dun..the moment of truth...
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 5:42pm
Bad news...still not even a hint of attempting to pump. It is much quieter than before...good or bad idk
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 11:58am
It appears that the (over) loading valve bearing ball is completely missing...could that cause the no hint of operation symptom? Its always returning to sump? What is the correct ball size? It looks to be about 1/8.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 12:10pm
The ball In the unloader has to be there. It is a one way check. Don't know size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 12:33pm
I found a 7/32 in grandpa's tool chest that's a close fit, but can't see well enough to be sure :(
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 1:50pm
This post seems to say that the ball is indeed 7/32...https://www.allischalmers.com/forum/ac-vs-modern-hydraulics_topic46904.html
This seems reasonable as it brings the plunger wear pattern in line with the fully depressed position...could also be the reason grandpa had a stash of 7/32 balls.
Edited by dfwallis - 22 Sep 2024 at 1:51pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 6:39pm
I damaged the larger drawbar/lift control housing gasket. The original (homemade possibly) gasket was .01" thick. The thinnest material I have is .03" I hope that thickness isn't critical.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 12:52pm
Fully disassembled and checked reassembled with unloading valve check ball installed...still not even a hint of function...attempted to prime before install, but there's no inlet check ball, so leaks back out during install...just about at wits end :( I must be missing something...
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 1:25pm
I've found one pic online the shows a check ball in the inlet of the pump...this one has no check ball there...should it?
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 12:00pm
After 4 attempts, left it at former agco dealer...he suggested pto gasket causing a dam, but verified not...oil reaches the lower inlet hole and pours out the upper hole before even registers on the dipstick.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 46 minutes ago at 7:29pm
Former AGCO dealer says his documentation shows there should be a checkvalve in the lower housing input port...of course not available and so far not enough detail to locate or design an alternate...now who removed it and why????? It must be press fit...the hole is a smooth bore.
1952 CA13092
