200 internal leak, quick fixes? |
INAllis ![]() Bronze Level ![]() ![]() Joined: 14 Feb 2024 Location: Indiana Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jun 2024 at 3:11pm |
1973 200, losing hydraulic fluid from left to right, hydraulic to diff? Realize it will require a split, anything I can do to get me through a few months until I can properly repair? I was thinking maybe a siphon hose??? Idk. TIA
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 606 |
I dont know how to overcome it externally but my daddy put a spicot on the differntiak drain and kept a gallon jug and a funnel and transfer fliud for three years until he traded it for a 7040
1984 80780
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1919 |
You can plumb them together to equalize them. Fill to the higher level of the 2 dipsticks. Probably thru the drain plugs. Someone with experience hopefully will answer with more details.
It has been talked about in other posts if you do a search I don't know if anything about it has been put in the knowledge section.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87611 |
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 954 |
Temporary fix has been to connect the Hydr & Tran/Diff compartment by going from front to rear drain plugs with a hose.
I worked on clutch in tractor that had been connected that way to get thru planting.
They'd removed 1/2" npt plug in torque tube & installed a 90 and reducing bushing 1/2 to 1/4", drilled & tapped tran plug to 1/4" npt, installed brass 1/4" 90 and ran a 1/4" hose between them. F Y I; A word of caution the Tran plug is directly above the drawbar, and there's not much clearance between drawbar and the 90. |
DPKII ![]() Bronze Level ![]() ![]() Joined: 08 Mar 2023 Location: Texas Points: 69 |
I recently did based on the pictures in the post above after finding oil dripping everywhere on the drawbar after about an hours use. I originally thought it was coming from the rockshaft as it was dripping from there but now I am thinking it may be coming from the lift cylinders. I installed the catch can to eliminate any metal shavings finding there way from transmission to hyro reservoir. I have a strong magnet in the bottom of the catch can as well. Wanted it semi-permanent as I will not be able to try spitting the tractor any time soon. Never split anything as large as the 190.
