Metal hydraulic lines on a 220 |
Kevin210
Silver Level Joined: 08 Oct 2018 Location: Indiana Points: 372 |
Posted: 16 Jun 2024 at 8:23pm |
Would ANYONE happen to have the four steel
hydraulic lines for a 220 that run under the fuel tank.I would love to have 4 good ones. Thanks. |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8207 |
Are the 253825,253826
Kevin210
I don't know part numbers.
There are only 4 lines that go to the back. I would just like to have 4 that aren't rusty/rusted or all bent up.. |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4802 |
I took 2 minutes and looked, the numbers Mike lists do appear to be the 4 that got to the remote couplers, on one type. Kevin, you need to go on agco partsbooks and decide which ones you need. There's probably some around off of pullers too, and rock valley salvage, and others.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2366 |
I've tried to find them, called several salvage yards,tried agco, with no luck, gave up and just replaced with hoses
Mikez
I looked again and realized there not what Kevin is looking for
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2528 |
I needed some for my D21 that I'm restoring and I wanted it back to factory parts and couldn't find them so I made my own. My original ones we just rusted out. but still had good shape, not bent.
I Just bought some tubing stock, got a pipe bender and bent them to look just like the original ones, cut the ends off the old tubes and just reused the original nut and backup ring. If your not the best at tube bending most hydraulic shops can bent them for you. just my experience. Dan
Edited by Acdiesel - 18 Jun 2024 at 11:04am |
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Kevin210
You just have to laugh and shake your head at some point.
It's a long story. When I did my 210 the lines were still in great condition and straight like they're suppose to be. What happened was I hung them on a trash barrel to drain not thinking about the trash truck picking up trash. So the trash truck guy assumed they were trash and threw them in the truck and of course they ended up at the landfill,Yes I meet the driver there and went through the load as it dumped and found them but one was ruined. I tried to get a line made in my area but no one could make the short bend where they fit above the fuel tank but I did get lucky and found some back then. But these on the 220 look like a snake in the grass. It seems that the quick bend I call at the connections is what they couldn't get right or something. I just want some that are in good condition I can just hookup and go.. Sorry so long... |
Kevin210
I'll check with rock valley this weekend.
Thanks guys. |
Acdiesel
Wengers of Meyerstown list some on there web site, you will need to match part numbers.
Dan
